MSPhysics: Collision Detection Offset and Joint Limits
Moderator: CPhillips
Postby Tim Danaher » Fri Apr 10, 2020 5:09 pm
Well, three years later and I finally get around to it...
I've got my design set up in MSPhysics (see my earlier post about one-handed brake lever design), but there always seems to be a 'barrier' around objects: I can't get them to touch, so the bottom lever never pivots. I can pivot it on its own, but can't get it to pivot using the upper lever blade.
Everything is modelled to scale.
I've searched, but I can't find anything about setting offsets for collision detection. Similarly nothing for limiting joint movement between certain angles (so objects don't spin freely). Can I do this?
TIA
Tim Danaher
Re: MSPhysics: Collision Detection Offset and Joint Limits
Postby ecati » Sat Apr 11, 2020 6:22 am
Can you share the skp file?
ecati
Postby Tim Danaher » Sat Apr 11, 2020 1:34 pm
Sure. What's the best way? Put it on the 3D Warehouse?
Tim Danaher
Postby Tim Danaher » Sat Apr 11, 2020 3:10 pm
It's on 3D Warehouse as Ergopower OHBL
Tim Danaher
Postby ecati » Sun Apr 12, 2020 8:00 am
If you mark "Collision Wireframe", you can see how the parts touch each other (picture 1).
You can fix this error by grouping the pieces separately (picture 2).
ecati
Postby Tim Danaher » Sun Apr 12, 2020 4:12 pm
Thanks ecati! Odd, I didn't get a notification... I'll have a look at this later...
Tim Danaher
Return to SketchyPhysics
Users browsing this forum: No registered users and 7 guests
