MS Physics and SU 2019
Only works for SU 2017. Is there an update in scope or do you know of a similar plugin to drop stuff at random in a basket for example? Really hope for a 2019 update - such an awesome plugin.
When will MSPhysics SU2019 work. Year is over.
Has there been any movement on this? Would love to use it in SU2020.
Hi All,
MSPhysics works well for me !
For that, you must put the MSPhysics directory and MSphysic.rb directly in the library directory of SKetchup 2019. Futhermore, you must add AMS_library 3.5.0 + with the extension manager.
if you have any difficulties, ask to me and i answer you
Best regard
Thierry -
@nesztler said:
Hi All,
Best regard
ThierryHi Thierry,
Do we need to install first the library? or it doesn't matter the order of installation.
Thanks in advance,
Jose Castellot -
@nesztler said:
Hi All,
Best regard
ThierryHey, could you let me know the exact route where you paste it ?i'm pretty nooby at this, also, do you copy the MSPhysics.rbx ?
thanks in advance! -
I can't load
2020 ?
Hello
I am new on MSPhisics and still using SU 2019. Already tryed to install first AMS Library and MSPhisics by using "Install extension" and and locate the file .rbz in the plugin Folder.
The plugin after installation seems are installed but alway this message:Error Loading File C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, "C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:inblock in require_all' C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in
each'
C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:inrequire_all' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in
<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in
require'
C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in
require'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:inload' C:/Users/Giuseppe.-------------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in
register_extension'
C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in<module:MSPhysics>' C:/Users/Giuseppe.------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in
<top (required)>'.Any one have suggestions ?
What's going one ?Thank's
Giuseppe
If you read through this thread you will see that the author has indicated it doesn't work in SketchUp 2019. See:
https://sketchucation.com/forums/viewtopic.php?f=61&p=669802#p646407
As of this date it has not been updated to work with SketchUp 2019 or newer.
