MS Physics and SU 2019Moderator: CPhillips
• Page 1 of 1
Re: MS Physics and SU 2019I got errors at startup too. I disabled it for now as i don't use it very often.
No it doesn't work with 2019 as of yet.
Re: MS Physics and SU 2019I don't get error messages, it just doesn't show up when I download it.
![]() Re: MS Physics and SU 2019lastimosamente no corre en 2019 es una pena considerando el potencial del pluguin esta revisando continuamente para ver si se resuelve el problema...
Re: MS Physics and SU 2019Only works for SU 2017. Is there an update in scope or do you know of a similar plugin to drop stuff at random in a basket for example? Really hope for a 2019 update - such an awesome plugin.
Re: MS Physics and SU 2019Hi All,
MSPhysics works well for me ! For that, you must put the MSPhysics directory and MSphysic.rb directly in the library directory of SKetchup 2019. Futhermore, you must add AMS_library 3.5.0 + with the extension manager. if you have any difficulties, ask to me and i answer you Best regard Thierry Re: MS Physics and SU 2019
Hi Thierry, Do we need to install first the library? or it doesn't matter the order of installation. Thanks in advance, Jose Castellot Re: MS Physics and SU 2019
Hey, could you let me know the exact route where you paste it ?i'm pretty nooby at this, also, do you copy the MSPhysics.rbx ? thanks in advance! Re: MS Physics and SU 2019Hello
I am new on MSPhisics and still using SU 2019. Already tryed to install first AMS Library and MSPhisics by using "Install extension" and and locate the file .rbz in the plugin Folder. The plugin after installation seems are installed but alway this message: Error Loading File C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!> C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all' C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `load' C:/Users/Giuseppe.-------------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension' C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>' C:/Users/Giuseppe.------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'. Any one have suggestions ? What's going one ? Thank's Giuseppe Re: MS Physics and SU 2019If you read through this thread you will see that the author has indicated it doesn't work in SketchUp 2019. See:
viewtopic.php?f=61&p=669802#p646407 As of this date it has not been updated to work with SketchUp 2019 or newer. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
• Page 1 of 1
