When I draw complex objects like curved cams I see that compound from CD is not working properly. I see some leftover lines when I check with collision wireframe. What can I do about it. A sample picture is attached?
The cam model is mirrored and grouped as single.
Problem with Compound from CD on Curvy faces.Moderator: CPhillips
• Page 1 of 1
Problem with Compound from CD on Curvy faces.Last edited by Europa on Fri May 05, 2017 8:14 am, edited 1 time in total.
Re: Problem with Compound from CD on Curvy faces.Yes, Compound from CD shape is unstable. You can use a plugin by Fredo6, called convexy, to divide the green piece into convex sub-groups. And also change the shape to Compound. Here it is: http://sketchucation.com/forums/viewtop ... 23&t=61145
• Page 1 of 1
