Problem with Compound from CD on Curvy faces.
Moderator: CPhillips
Postby Europa » Fri May 05, 2017 8:09 am
When I draw complex objects like curved cams I see that compound from CD is not working properly. I see some leftover lines when I check with collision wireframe. What can I do about it. A sample picture is attached?
The cam model is mirrored and grouped as single.
Europa
Re: Problem with Compound from CD on Curvy faces.
Postby Anton_S » Fri May 05, 2017 9:31 am
Yes, Compound from CD shape is unstable. You can use a plugin by Fredo6, called convexy, to divide the green piece into convex sub-groups. And also change the shape to Compound. Here it is: http://sketchucation.com/forums/viewtop ... 23&t=61145
Anton_S
PluginStore Author
PluginStore Author
Postby Europa » Fri May 05, 2017 2:49 pm
Thank you Anton.
Europa
Return to SketchyPhysics
