Bowling ball roll
Moderator: CPhillips
Bowling ball roll
Postby drafter » Sat Dec 10, 2016 8:09 pm
Win 8.1, 32 bit, sketchy physics, SU Make 2016
Have bowling alley (dwg) with ramp to start bowling ball. Ball rolls about half way then peters out.
File attached. What factor must be changed to cause ball to keep rolling?
drafter
Re: Bowling ball roll
Postby SketchyPhysicsNutt » Mon Dec 12, 2016 2:09 am
Hi drafter i had play with your model and to get the strike power u need
i added a servo with hammer strike lever (both can be hidden from view)
press (S key) for strike and tweak strength and acceleration for your needs
BowlingAlley2
https://file.town/download/iwjof9w8wlcpdse8tsibdo53h
Hope it helps
Tez
SketchyPhysicsNutt
Postby drafter » Mon Dec 12, 2016 3:40 pm
SketchyPhysicsNutt wrote:Hi drafter i had play with your model and to get the strike power u need
BowlingAlley2
Hope it helps
Tez
Thank you much. Are there other keyboard shortcuts you can share?
drafter
Postby SketchyPhysicsNutt » Tue Dec 13, 2016 11:00 am
all scripts below go in controller panel
motor joints
key('z')-key('x') .........left/right
(0.5-rightx) ........left/right arrow keys
(0.5-righty) ........up/down arrow keys
servo joints
one for your bowling alley model automatic strike at frame 300
[0,1][(frame/300)%2] ....set servo min to -0.00
(rightx) ........left/right arrow keys
key('z')-key('x') .........left/right....set servo min to -0.00
oscillator(300) .......left/right...automatic
on joypad sticks or W,A,S,D keys
(joyLX) .....left to right / leftstick
(joyLY) .....up/down / leftstick
(joyRY) .....left to right / rightstick
(joyRX) .....up/down / rightstick
make sure u plug in joypad before u startup sketchup
SketchyPhysicsNutt
Postby drafter » Sun Jan 01, 2017 11:12 pm
BowlingAlley2
Hope it helps
Tez
When I open this "revised" dwg, Controllers are absent. I don't know why.
drafter
Postby SketchyPhysicsNutt » Tue Jan 03, 2017 12:53 pm
Hi mate don't understand what u mean by "Controllers are absent"
this may help u out
Tez
SketchyPhysicsNutt
Postby drafter » Tue Jan 03, 2017 7:22 pm
SketchyPhysicsNutt wrote:Hi mate don't understand what u mean by "Controllers are absent"
this may help u out
Tez
When I his "start", A blank panel, where you expect to find controllers for such things as servos, is "Blank".
drafter
Postby drafter » Tue Jan 03, 2017 8:04 pm
this may help u out
Tez
Hold the phone!!
Tried it again and it works fine.
What threw me off was the letter "S" is the keyboard short-cut for SCALE. So the icon for scale kept appearing. So I deleted the short-cut.............And ALL is well.
Thank you for your time.
drafter
Return to SketchyPhysics
