How to SP 3.4 and KerkyThea
Moderator: CPhillips
Postby Anton_S » Mon Sep 01, 2014 3:37 pm
Before you get going, ensure that you have Kerkythea and SU2KT plugin installed.
Here is a little tutorial on how to export SP3.4 animation to Kerkythea.
  1. Open SP model you want to export.
  2. Enable recording.
  3. Start simulation, and run it for desired time.
  4. Reset simulation. It will ask you to save animation, press YES.
  5. Optional: Open Ruby console. It will show you export statistics after you complete all the steps below.
  6. Select Menu (Plugins) > Sketchy Replay > Export to Kerkythea
  7. Go through options. Two options dialogs will show up. Once you adjust the first options, press OK, the next options dialog will show up. Adjust resolution, rate, and other stuff. Set 'Replay Camera?' to YES if you want to replay camera positions recorded during simulation. Note: If it's your first time using Kerkythea for SU, a window will show up asking you to locate Kerkythea. Simply locate Kerkythea.exe, which is most likely in C:\Program Files\Kerkythea Rendering System\Kerkythea.exe. Such window will show up after the first options dialog.
  8. When it gets to exporting, please wait as there is no way you can stop it other than terminating SketchUp application. It may appear frozen, but it's still responding.
  9. After it finishes it will ask you whether to start rendering. You may press YES to do so, or NO if you want to adjust animation settings.
  10. To adjust animation colors, materials, sky, and other properties open (model).xml and make you changes. Once you're complete, save scene, i.e overwrite (model).xml, go to menu (Menu) File > Run Script... and select (model).kst to render.
  11. Now, once all rendering is complete, you may use an animation tool to combine all rendered images into one video. I suggest using MakeAVI. Add all images, and press the Begin! button. An options dialog will show up to adjust Compressor. Set it to Full Frames (Uncompressed) for good quality. Your animation will be ready once the MakeAVI finishes creating the avi file.
Here is a little Demo. Of course it could have been better than that.
Here are more professional videos created by Sang Hun Lee:
6
Anton_S
PluginStore Author
PluginStore Author
Re: How to SP 3.4 and KerkyThea
Postby tallbridgeguy » Mon Sep 01, 2014 4:43 pm
Looking good!
Thanks! :thumb: :thumb:
s
tallbridgeguy
Postby Oxer » Thu Sep 04, 2014 4:56 pm
Thanks for the info!! :thumb:
The instructions have worked fine too with Thea Render, but I have a question:
Is it possible export the movement of the camera while simulation is running?
http://www.oxervision.blogspot.com/
Oxer
Postby Anton_S » Thu Sep 04, 2014 9:31 pm
Oxer wrote:Thanks for the info!! :thumb:
Camera positions are recorded automatically, but it will be up to you to decide whether to export with camera positions. Set 'Replay Camera?' to YES when going through export options.
Anton_S
PluginStore Author
PluginStore Author
Postby Oxer » Fri Sep 05, 2014 2:17 am
Yes, that is correct :thumb: . I tried the same with Thea Render but when I execute the .kst file the positions of the camera are deleted, always it render the same fixed position of the camera, like a isometric view with the origin of model in the center of the image. :(
Oxer
Postby Anton_S » Fri Sep 05, 2014 4:05 am
Oh, you're speaking of running (model).kst in Thea Render not Kerkythea. I will look into it.
Anton_S
PluginStore Author
PluginStore Author
Postby Oxer » Fri Sep 05, 2014 5:08 am
Yes, the problem is with Thea Render and the position of the Camera (## Current View ##).
Oxer
Postby tomasz » Fri Sep 12, 2014 7:25 am
Very good work Anton! I am impressed. :ecstatic:
I think many of us were waiting for this to come. Thank you!
I will add support for 3.4 in 'Thea for SketchUp'.
tomasz
SU2TH & SU2KT Developer
Postby tomasz » Fri Sep 12, 2014 7:29 am
Do you mind sharing the sample model?
tomasz
Postby Anton_S » Fri Sep 12, 2014 9:24 am
tomasz wrote:Do you mind sharing the sample model?
tank threads.skp
Here are the steps I did:
  1. Enable recording
  2. Play simulation
  3. Right click on front wheel, and select camera follow.
  4. Hold the 'w' key to drive the chain.
  5. Run simulation for desired time
  6. Proceed from first post, step 4.
tomasz wrote:Very good work Anton! I am impressed. :ecstatic:
Thank you!
As Oxer stated exported camera positions don't change when run (model).kst in Thea Render, but do change when run it in Kerkythea Render. Maybe certain merge options have to be added? Well, I'm not an expert. I hope you look into it. Good luck, thea is an amazing tool!
Anton_S
PluginStore Author
PluginStore Author
Postby Oxer » Fri Sep 12, 2014 11:52 am
Tomasz wrote:Very good work Anton! I am impressed. :ecstatic:
Good news for Thea's users!! :bounce:
Oxer
Postby aviv » Thu Nov 27, 2014 8:58 pm
hi Anton
unfortunately it didnt work for me.
i downloud kerkythea for skt and follow your steaps from 1-4 it was ok
step 5- i opend the ruby console it was empty
i followed step 6
on step 7 i got an > exporting option< geometry,light, ....
nothing about resolution , rate , or "replay camera"
and no exportin
a few weeks ago i followed your advice and used exporting by "make avi" it wasn't good enough
your help
please
aviv
aviv
Postby Anton_S » Thu Nov 27, 2014 11:52 pm
For step 5, the export statistics will be shown after you finish with the rest of steps.
For step 7, you get two setting dialogs. One dialog is for export options, then once you click OK, the other dialog with animation export options will show up. I.E there are two options dialogs that will show up in the process. I will update instructions in first post, so they sound clear.
When using MakeAVI, set compressor option to Full Frames (Uncompressed) for good quality. It will show up after you click the Begin! button and set export path.
Anton_S
PluginStore Author
PluginStore Author
Postby aviv » Fri Nov 28, 2014 11:04 am
to be more specific - after the first dialog <export option> <ok> i get an open file <locate kerkythea program, please>
no second dialog.
aviv
Postby Anton_S » Fri Nov 28, 2014 7:16 pm
Oh, that's because you also have to install Kerkythea. Once you do so, upon the first try you have to locate Kerkythea.exe, which is most likely in C:\Program Files\Kerkythea Rendering System\Kerkythea.exe
Anton_S
PluginStore Author
PluginStore Author
Postby aviv » Fri Nov 28, 2014 10:24 pm
of course i dowloded the kerkythea and it is on program files (x86) (and working
i succeed exporting a modle) .but where should i locate it?
thnks for your help
aviv
Postby Anton_S » Fri Nov 28, 2014 11:00 pm
aviv wrote:of course i dowloded the kerkythea and it is on program files (x86) (and working
thnks for your help
You locate it there where you saved it. After you adjust settings in two dialogs (Step 7), you get another window, asking where to save the script and animation files...
Anton_S
PluginStore Author
PluginStore Author
Postby aviv » Sat Nov 29, 2014 12:23 am
nothing new it the same. maybee i missing a file i see "kerkythea rendering system" but no "kerkythea exe"?????
aviv
Postby Anton_S » Sat Nov 29, 2014 2:50 am
aviv wrote:nothing new it the same. maybee i missing a file i see "kerkythea rendering system" but no "kerkythea exe"?????
I don't know what you doing wrong, nor I understand what's the problem.
Lets go back to initial steps:
  • Do you have SketchyPhysics 3.5.x installed?
  • Do you have KerkyThea Application installed?
  • Do you have SU2KT 3.17+ Plugin installed?
Anton_S
PluginStore Author
PluginStore Author
Postby aviv » Sat Nov 29, 2014 8:28 pm
once again i want to thank you for your help.
i uninstall kerkythea and install it again and now it is locate and working :ecstatic:
i made a simple polygon a cube moving across the frame rendring 4 frame just to see if i am doing ok
it is rendring for more then an hour. how do i now when it finished?
what is the next step ?
iam planing upgrade to pro 2015 is physics get along with it?
THANKS
aviv
aviv
Postby Anton_S » Sat Nov 29, 2014 11:49 pm
Speaking of rendering, Kerkythea application has its own progress clock:
This clock will disapera when the rendering is complete. It's not a rocket science...
And before rendering, I suggest using TT CleanUp plugin to remove all unused components and geometry. It will improve the speed of rendering.
See the list in first post for next step.
SketchyPhysics will not work in SU2015 64bit, but it will work in SU2015 32bit.
Anton_S
PluginStore Author
PluginStore Author
Postby valerostudio » Thu Jul 12, 2018 12:47 pm
Will we see support for VRay anytime in the future?
valerostudio
Return to SketchyPhysics
