SketchyPhysics3 FAQ.
Moderator: CPhillips
Re: SketchyPhysics3 FAQ.
Postby jaysax » Mon Oct 24, 2011 5:13 pm
Looks like things got clarified, or even pleasantified, if at a remove of some years. Huzzah!
jaysax
Postby mptak » Wed Oct 26, 2011 3:28 pm
Whenever I miss the brilliant things that CP drops out of the sky every now and then I just go back to the Sketchy Physics Piano and try plunk out a little tune. I hope all is well.
mptak
Postby jgb » Thu Nov 03, 2011 3:20 pm
Me thinks Mr. Phillips is loosing (lost :?: ) interest in supporting SketchyPhysics. :shock:
He is less than responsive to posts, and updates are non-existant. :thumbd:
We've known for a long time he doesn't like documenting much, which is an occupational hazard for innovative developers. But super simple stuff like maintaining his SketchUcation page with basic release info has fallen to the wayside. :puke:
It's a shame though. SP is really neat, but in need of some upgrades Chris promised that never transpired. :cry:
__________________
jgb
jgb
Postby Crankston Shnord » Sun Nov 20, 2011 11:27 pm
Question:
I am trying to use a slider to power a simple gun. I grouped the slider to the "bolt" (the part that I want to slide) but when I try to parent it to the barrel than nothing happens. I select the parent tool, and than CTRL-Click the barrel. All that happens is that the joint-connector tool selects the barrel, but it doesn't parent the slider. Any thoughts? EDIT: I am using Sketchup8 and SP 3.1.
Crankston Shnord
Sketchup Modeler,
Blender Designer,
Renderer
My Models
Crankston Shnord
Postby emanuelson87 » Fri Jan 20, 2012 11:08 pm
=Physicsguy= wrote:
Sgal wrote:5. Object can be linked to more than one joint, and vice versa.
Actually, Connecting two objects to a single controlled joint will not work correctly. Either object will take on a static position once the simulation is commenced.
I have a problem I can not see the SketchyPhysics Inspector window comes in blue and does not make me change the parameters of my project ... I'm going crazy aiutatemieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
emanuelson87
Postby emanuelson87 » Sat Jan 28, 2012 1:16 pm
Hi I have a problem with SketchyPhysics every time I try to activate the SketchyPhysics Inspector gives me an error in the console and the ruby code
quietly_force_sync_mats_cb just calledpotentialParent #<Sketchup::ComponentInstance:0x1844c6b4>
emanuelson87
Postby malveira » Thu Jun 06, 2013 8:17 am
What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?
Cheers!
malveira
Postby mptak » Fri Jun 07, 2013 5:01 am
"What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?"
I don't think that direct action/reaction between the propeller and bouyant water is possible. You can link the propeller rotation and perhaps a push ([x,y,x]) function in some ruby script or else a hidden thruster attached to the boat. Hope this helps
mptak
Postby StevenGerritsen » Wed Sep 10, 2014 5:00 pm
Hello,
how do i export an sketchy Physics animation? F.a. in avi or any other size.
gr Steven
StevenGerritsen
Postby deskpilot » Tue Jan 20, 2015 2:46 am
Steven, see "Exporting animation" in my 'Simulation Aborted' thread. Anton takes you through the steps but it's not straight forward nor easy.
deskpilot
Postby Anton_S » Tue Jan 20, 2015 3:29 am
Good to see deskpilot helping out :)
Steven, here is the thread that deskpilot talked about: viewtopic.php?f=61&t=60419#p552495
Also, SketchyPhysics 3.5.5 main thread has various "how to" links, including how to export animation.
Anton_S
PluginStore Author
PluginStore Author
Previous
Return to SketchyPhysics
