Salut !
Voici un petit script qui permet de purger tous les elts inutilisés, sans passer par fenêtre/Infos du modèle/Statistiques.
Dans le menu plugins, et un icône seul.
Purger
• Page 1 of 1
PurgerFrenglish at its best !
My scripts Re: PurgerDear Matt,
Do you plan to issue an English version? I note that you use a paint brush as the purge icon. This icon is used in other software (AutoCAD etc) to 'match properties'. I would suggest using a funnel, but this is often used as the icon for 'filter', but then I suppose purging is a form of filtering. Kind regards, Bob Re: PurgerHi watkins !
It's a broom (Not on the translation ![]() ![]()
Ok ! Tell me what you think about this icon ! Frenglish at its best !
Many thanks for the English version, and yes, I like the new Icon better. How does your script differ from TIG's PurgeAll.rb? It purges all unused components, layers, materials and styles, and one can choose which type(s) to purge from a dialog (Yes/No). Regards, Bob Re: Purger
One step less... I didn't see it before !!! Frenglish at its best !
My scripts
• Page 1 of 1
