Flextools Windows and Adjacent Pastes  Topic is solved
Discussions for FlexTools - Responsive Sketchup Modeling
Postby ArchiJeff » Tue Jul 30, 2019 12:56 am
Greetings! As you can see in the image below inserting my awesome flextools window dyn component works flawlessly as long as it is pasted away from another flextools window. When I paste or insert it directly adjacent to an existing flextools dynamic window it doesn't cut the wall. What am I missing and thanks for your time!
ArchiJeff
Premium Member
Premium Member
Re: Flextools Windows and Adjacent Pastes
Postby juju » Tue Jul 30, 2019 10:30 am
select the offending DC and press the refresh button
if you press the refresh button without pre-selecting a DC then all DC's get recalculated
User avatar
juju
Premium Member
Premium Member
Re: Flextools Windows and Adjacent Pastes  Topic is solved
Postby halroach » Tue Jul 30, 2019 12:32 pm
ArchiJeff wrote:Greetings! As you can see in the image below inserting my awesome flextools window dyn component works flawlessly as long as it is pasted away from another flextools window. When I paste or insert it directly adjacent to an existing flextools dynamic window it doesn't cut the wall. What am I missing and thanks for your time!
Hi Jeff,
Because of current limitations in the wall cutting algorithm, when you try to paste two wall cutting components side by side, in most cases, one of them will not cut an opening (Sometimes it will cut if one of the components is a bit smaller vertically).
But, we made it so the components can be combined. With a few alterations you can join them together so they look like one, and you can then place them into a new wall cutting component. You can see how that can be done in the following video:
We have some ideas for future development of more window variations so you wouldn't need to combine windows, and possibly improving the wallcutter algorithm so you could do what you're asking for. Currently though I don't have an exact time frame for that, so combining flex components is the best solution for now.
I hope that helps.
User avatar
halroach
Postby ArchiJeff » Tue Jul 30, 2019 4:04 pm
Thank you very much halroach. I appreciate you work and your dedication. I will do as the video indicates and push forward! I look forward more awesomeness from flextools.cc.
Cheers!
ArchiJeff
Premium Member
Premium Member
Postby halroach » Tue Jul 30, 2019 4:42 pm
ArchiJeff wrote:Thank you very much halroach. I appreciate you work and your dedication. I will do as the video indicates and push forward! I look forward more awesomeness from flextools.cc.
Cheers!
You're welcome Sir! Thanks for the kind words :)
Yoni
User avatar
halroach
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to FlexTools
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
