3-in one window
Discussions for FlexTools - Responsive Sketchup Modeling
3-in one window
Postby Epix3D » Wed May 01, 2019 10:36 am
How would you go about to make this kind of window?
User avatar
Epix3D
Premium Member
Premium Member
Re: 3-in one window
Postby halroach » Thu May 02, 2019 6:37 am
Hey Epix,
It's not a total super convenient solution yet, but you can combine windows like in the following video:
User avatar
halroach
Re: 3-in one window
Postby HornOxx » Thu May 02, 2019 7:53 am
hi - I'm not sure it's what you're asking or looking for.
Usually I use my own standard window components. I have optimized these windows a bit for my own following rendering process. If I have to, I vary the thicknesses of the mounting frames and the opening frames or any othe detailing. These window components I copy-paste then into the already done simple self-cutting opening components...
never trust a skinny cook
User avatar
HornOxx
Re: 3-in one window
Postby Epix3D » Thu May 02, 2019 8:50 am
halroach wrote:Hey Epix,
Thank you Halroach. I knew I´d seen this video before. Just what I was looking for :thumb:
User avatar
Epix3D
Premium Member
Premium Member
Re: 3-in one window
Postby Epix3D » Thu May 02, 2019 9:52 pm
I have another question..
Is it possible to adjust lenght/widh of sill beyond the interactive click length?
User avatar
Epix3D
Premium Member
Premium Member
Re: 3-in one window
Postby halroach » Fri May 03, 2019 12:57 am
Epix3D wrote:I have another question..
Yes, of course!
1. Look for the setting: "(Interact Tool) Protrusions 0 Or"
This will extend the sill to the sides. If it doesn't extend to the new length, use the interact tool once or twice to get it to extend again.
2. You can change how the sill extends outward or inward with the "Out" and "In" settings - Note that for the sill to be correctly positioned so that it is flush with the wall when In and Out are set to 0, you must set the "Wall - Thickness" so it matches the wall you are placing the window on.
User avatar
halroach
Re: 3-in one window
Postby Epix3D » Fri May 03, 2019 9:32 am
Super Halroach! Actually I allready found/tested that setting but did not click interact twice.
User avatar
Epix3D
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to FlexTools
Who is online
Visit our sponsors:
