FlexTools and Profile Builder
Discussions for FlexTools - Responsive Sketchup Modeling
Postby SiPieFace » Thu Feb 14, 2019 6:30 pm
I'm looking to purchase a couple of plug-ins that will speed up my work flow considerably.
Profile Builder looks ideal for the creation of multi-layered external and internal walls but it doesn't create parametric holes. I also love the flexibility of FlexTools (along with the WallCuter plugin) and what this has to offer.
An ideal situation would be if Wall Cutter and/or FlexTools (windows/doors) would cut parametric holes (and be adjustable on the fly) within Profile Builder multi-layered walls.
Has anyone tried this and had any success?
SiPieFace
Re: FlexTools and Profile Builder
Postby pilou » Thu Feb 14, 2019 7:37 pm
Maybe try also Flextools! ;)
Speedy Galerie
Top SketchUcator
Postby SiPieFace » Thu Feb 14, 2019 8:08 pm
That is genuinely awesome. This could be a game changer for me. One last question is whether anyone has tried them in conjunction with Skalp? If I could model like this and output drawings with hatching on sections this would solve all of my current modelling issues.
SiPieFace
Postby juju » Thu Feb 14, 2019 8:13 pm
SiPieFace wrote:One last question is whether anyone has tried them in conjunction with Skalp?
It works.
juju
Premium Member
Premium Member
Postby gameongrant » Thu Feb 14, 2019 11:20 pm
I've found it works in theory but never the way I want it to. If you alter your wall (i.e. path) everything resets and you have to recut all the components again. I also group all my windows and doors which also creates problems with the cutting tool and it doesn't work. I'm sure you can get them to play better but it'll mean altering my workflow. I currently use Mike brightman's and it just doesn't work. I, like yourself would like to know the best method for using both tools for multilayered walls in architecture.
gameongrant
Postby pilou » Thu Feb 14, 2019 11:52 pm
Speedy Galerie
Top SketchUcator
Postby SiPieFace » Thu Feb 14, 2019 11:58 pm
gameongrant wrote:I've found it works in theory but never the way I want it to. If you alter your wall (i.e. path) everything resets and you have to recut all the components again. I also group all my windows and doors which also creates problems with the cutting tool and it doesn't work. I'm sure you can get them to play better but it'll mean altering my workflow. I currently use Mike brightman's and it just doesn't work. I, like yourself would like to know the best method for using both tools for multilayered walls in architecture.
What combo of plugins do you use? What's the basis of your workflow?
I've never had a look at the Condoc's method as I've never considered using SU right through the process (inception to completion), it's always been used for conceptual design and massing only then into AutoCAD or Revit. But now I'd like to go SU for the lot but I need some elements of parametric modelling in my workflow or there's just too much manual time-consuming 'dumb' modelling work required to get it all done and which my fees won't cover.
The search for suitable plug-ins comes from necessity and because of the total lack of interest by Trimble in adding genuine BIM (and parametric) features to SU.
SiPieFace
Postby pilou » Fri Feb 15, 2019 12:05 am
Parametric Modeling but you must have some learning! ;)
Speedy Galerie
Top SketchUcator
Postby SiPieFace » Fri Feb 15, 2019 12:39 am
I'm an architect so my workflow and requirement for parametric modelling features within my software of choice relates to that. I need windows/doors to embed into walls and be adjustable on the fly and readjust to suit. Flex Tools appears to do this. I'd like to be able to create parametrically adjustable multi-layered walls (and floors) and Profile Builder appears to do the walls part at least. I need hatching for construction docs and Skalp does that but I need them all to work together.
I'd also like to able to parametrically tag windows, doors etc and generate linked schedules from these tags but have no idea if this is even possible in SU or LO......If SU had just 10% of the useful elements of Revit but retained it's user friendliness and organic nature it'd be all things to all architectural types......But we're still waiting Trimble.
SiPieFace
Return to FlexTools
