Error running ComponentFinder
Discussions for FlexTools - Responsive Sketchup Modeling
Postby wenzhi1099 » Fri Nov 30, 2018 4:00 am
After installing ComponentFinder, I reload the SU, and then prompt error, like this
Error: C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/openssl.rb:17:in `<top (required)>'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/modules/application.rbe:3:in `<main>'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in `eval'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in `require'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in `main'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:80:in `<module:FlexTools>'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:15:in `<module:F3d>'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:14:in `<main>'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `eval'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in `<module:FlexTools>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:7:in `<module:F3d>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:6:in `<top (required)>'
Error: #<NameError: uninitialized constant F3d::FlexTools::Application>
c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:76:in `main'
how can i fix it?
thank you
wenzhi1099
Re: Error running ComponentFinder
Postby halroach » Sat Dec 01, 2018 12:46 pm
Hi Wenzhi,
We have seen this error come up a few times before. Please see the following explanation and solution:
https://flextools.cc/help/load-error-127/
halroach
Postby TIG » Sun Dec 02, 2018 12:31 am
I am not a FlexTool expert.
However, there might be a clue in your error message...
Code: Select all
Is your normal Windows user-name 'Administrator' ?
Usually you'd choose something like 'Wenzhi' ?
Assuming it is your normal Windows user-name...
When you initially installed SketchUp did you do it in the proper way ?
Even if you [as a normal Windows user] have admin-powers you must install complex apps this way...
[Note that if SketchUp is already installed you should close it, then choose the Repair option offered...]
Find the SketchUp installer exe file - probably in your downloads folder ?
Select that exe file's icon.
Right-click > context-menu > "Run as administrator"
When prompted choose "Repair" and agree to all prompts thereafter...
[If it's a fresh install choose "Install" !]
Installing it in any other way - even if you have full admin-powers is not the same thing.
Double-clicking on the exe file's icon might 'Run' it, but NOT as 'the administrator'.
It's not recommended to run SketchUp while logged in as the full 'system-administrator' - but if you have another user-name called [confusingly] 'Administrator', probably with admin-powers that IS OK, BUT you will still need to use "Run as administrator"... as explained...
If you have really messed up permissions on the C:/Users/Administrator/AppData/Roaming/SketchUp path then you might also need to fix then using Right-click > context-menu > Properties > Security > Edit and ensure that every entry has 'Full Control' set and that this permissions trickles down to apply to all subfolders and files in the tree...
Global Moderator
Return to FlexTools
