Door Handles
Discussions for FlexTools - Responsive Sketchup Modeling
Door Handles
Postby Ben Ritter » Wed Jan 31, 2018 7:52 pm
How would I get the door handles to properly move if I change the thickness of the door? If I go into the nested door handle component and move it manually, it snaps back to it's original position
Ben Ritter
Re: Door Handles
Postby halroach » Thu Feb 01, 2018 3:53 pm
Hi Ben,
When you change the thickness of the door from within the component options, the handles should adjust automatically.
If you want to change the door handle height and distance, there are settings for that within the component options.
If you’re using the ‘cutter’ component, to get to those settings you have to double click on the door and then select the inner component.
halroach
Re: Door Handles
Postby Ben Ritter » Fri Feb 02, 2018 4:08 pm
halroach wrote:Hi Ben,
Hello, the handles did not move when I changed the door thickness, so that was why I asked.
Thanks.
Ben Ritter
Re: Door Handles
Postby halroach » Fri Feb 02, 2018 5:53 pm
Ben Ritter wrote:Hello, the handles did not move when I changed the door thickness, so that was why I asked.
Thanks.
Does this happen with new doors you place into a new model?
Are other settings in the door working fine?
Please send me a file where the door handles aren't changing to fradnzel3d@gmail.com
halroach
Re: Door Handles
Postby halroach » Sat Feb 03, 2018 5:03 am
Hi Ben,
Looking at the file you sent, it seems like you have accidentally edited the door thickness attributes, and possibly other entries, from within the "Attributes Editor" which is meant for authoring/programming the components inside behaviors. Doing those edits, broke a few things inside the component.
Make sure that when you edit the components, you do so from within the "Component Options" window only. (Unless you meant to program additional/different behaviors, but then things can break if not done right).
When you open a new model, and place a new door, it should be fine, is it not? If it's not fine, let me know.
Generally, when encountering odd behaviors like this, it's always best to place a new "fresh" component and make the edits again.
halroach
Re: Door Handles
Postby Ben Ritter » Sun Feb 04, 2018 2:41 am
Yoni,
Thanks again for straightening me out. I can insert Flex Doors without any issues.
Can't wait for the Cutter doors to have all the same option selections as the standard doors. :)
Ben Ritter
Re: Door Handles
Postby halroach » Sun Feb 04, 2018 3:16 am
Ben Ritter wrote:Yoni,
Glad it’s working :)
The cutter doors have the same options (plus additional extra wall options). The rest of the options are one level deep, so you need to double click and select the inner component to get to them.
halroach
Return to FlexTools
