FlexTools Updates
Discussions for FlexTools - Responsive Sketchup Modeling
Re: FlexTools Updates
Postby halroach » Thu Jan 24, 2019 6:08 am
Epix3d wrote:Thank you Juju,. I will try that next time.
I have suggestion.
I often use CleanUp3 plugin to clean my files for unecessary geometry.
The door arc in FleTools Doors should be locked to avoid disappearing when cleaning for stray lines.
[img]
[/img]
I don't quite remember why now, but something tells me not to lock components by default. Maybe it's the red color every time you select the component... :)
Other than locking, another thing you could try in order to avoid the lines getting erased is to open the arc component and draw the radius lines so a surface is generated. Then hide the lines and the surface.
See if that works.
After which ever change suits you, you can then save the component aside with ComponentFinder for future use.
halroach
Postby Epix3d » Thu Jan 24, 2019 10:27 am
I cannot find any problem with locking the arc by default as it is locked steps inside the component.
i have made some door libraries previously working like this. If you want to delete the arcs(which should not be necessary as it is on own layer) you just unlock it.
I think default is best way to avoid customers deleting arcs by mistake.
Epix3d
Premium Member
Premium Member
Postby pilou » Fri Jan 25, 2019 1:01 am
seems all works fine! ;)
Speedy Galerie
Top SketchUcator
Postby halroach » Mon Feb 04, 2019 1:08 pm
You can now produce 45(+) different Dynamic Doors, thanks to Mr. pcmoor and his extremely useful Multi Dynamic Door Panel.
How? By combining it with FlexDoor :)
We've known about this multi door panel component for quite some time now, but it had a catch. The minute you made a copy of it, and altered one of the copies, both DCs would jumble up with sub-components flying all around your model. The only solution was to delve deep into each component and make all of it's sub-components unique - A very time intensive process. So... we decided to develop a tool just for this called 'Make Totally Unique'. After applying this tool to your new door variations, the door and all of it's sub-components will instantly become unique and they will all behave just right.
See more details in this FlexBlog post.
halroach
Re: FlexTools problem
Postby porschegt2 » Mon Feb 04, 2019 7:05 pm
Hi all,
Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
thanks a lot
carlos
porschegt2
Postby juju » Mon Feb 04, 2019 7:43 pm
click into them a level or so to access more DC options
juju
Premium Member
Premium Member
Postby halroach » Tue Feb 05, 2019 5:41 am
porschegt2 wrote:Hi all,
thanks a lot
carlos
Hi Carlos,
I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
* Edit for reference:
The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
More about this issue at: https://forums.sketchup.com/t/error-on- ... w/19991/21
halroach
Postby Ivan K » Wed Feb 27, 2019 3:15 pm
Just came to say a very big thank you to you all for including the hidden door!
I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
Thank you!
Ivan K
Postby juju » Thu Feb 28, 2019 8:10 pm
Yoni, can you look into incorporating the PCMoor DC door as well?
juju
Premium Member
Premium Member
Postby halroach » Fri Mar 01, 2019 6:17 am
juju wrote:Yoni, can you look into incorporating the PCMoor DC door as well?
Hey Juju,
I'm unaware of this DC door. Can you send a link?
When you say to incorporate, do you mean to get it to work as a wall cutting component?
halroach
Postby halroach » Fri Mar 01, 2019 7:06 am
We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
Learn more about how to hide frames in this FlexBlog post.
halroach
Postby juju » Fri Mar 01, 2019 9:59 am
Hey Juju,
Man, you guys must be real busy... :thumb: ;)
See your BlogPost & mail comms of 01 February 2019.
juju
Premium Member
Premium Member
Postby halroach » Fri Mar 01, 2019 10:24 am
juju wrote:Man, you guys must be real busy... :thumb: ;)
Hah :)
Well... we are crazy busy, that's true!
I thought you were referring to a different (complete) door component that I haven't seen in the 3D warehouse, and not to the dynamic panel.
The blog post/video basically show how to insert the door panel into FlexDoor, and you can always save it aside with Component Finder for later use.
We could theoretically incorporate it into one of our components by default... but should we?
It's a cool panel, though the workflow with it - the need to use the 'make totally unique' tool, isn't a straight forward process. I think it would confuse and frustrate sketchuppers who first install flextools. They would copy the door around and then find that things are acting really weird with components flying around, and they wouldn't know why. It's also a bit heavy/slow in larger models. I think it would be problematic.
halroach
Previous
Return to FlexTools
