Discussions for FlexTools - Responsive Sketchup Modeling
by mogren » Tue May 12, 2020 12:36 pm
Exemple
mogren
- Name: Thierry F.
- Operating system: Mac
- License type: Pro
- SketchUp use: product design
by pilou » Tue May 12, 2020 1:43 pm
Hospices imaginaires ou ayant existés ?
- Top SketchUcator
- Name: Pilou
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by mogren » Tue May 12, 2020 1:56 pm
pilou wrote:Hospices imaginaires ou ayant existés ?
Décor film
mogren
- Name: Thierry F.
- License type: Pro
by halroach » Tue May 12, 2020 4:42 pm
mogren wrote:What I would like
You should be able to get that with the following settings. 'Inset' to move the window in/out in relation to the wall. 'Frame - Depth' to get it as deep as you need. Play with the 'Frame - Width' setting to change what you wrote as Height in your picture. flexwindow arch in arch settings.png
halroach
- Name: Yoni Frandzel
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
by mogren » Tue May 12, 2020 9:07 pm
halroach wrote:mogren wrote:What I would like
To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
mogren
- Name: Thierry F.
- License type: Pro
by pilou » Tue May 12, 2020 10:59 pm
Je crois que oui, c'est ce qui était décrit dans les posts précédents  Il faut utiliser 2 composants l'un dans l'autre! I took two arch components, and placed one in the other.
- Top SketchUcator
- Name: Pilou
by mogren » Wed May 13, 2020 10:32 am
pilou wrote:Je crois que oui, c'est ce qui était décrit dans les posts précédents  Il faut utiliser 2 composants l'un dans l'autre! I took two arch components, and placed one in the other.
Oui effectivement pardon j'ai posé la question trop vite
mogren
- Name: Thierry F.
- License type: Pro
by mogren » Wed May 13, 2020 10:35 am
mogren wrote:pilou wrote:Je crois que oui, c'est ce qui était décrit dans les posts précédents  Il faut utiliser 2 composants l'un dans l'autre! I took two arch components, and placed one in the other.
Oui effectivement pardon j'ai posé la question trop vite Ceci dit l'idéal n'est pas encore là
mogren
- Name: Thierry F.
- License type: Pro
by pilou » Wed May 13, 2020 11:44 am
I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version!
- Top SketchUcator
- Name: Pilou
by halroach » Wed May 13, 2020 12:20 pm
pilou wrote:I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version!
Updated to 2017!
halroach
- License type: Pro
by pilou » Wed May 13, 2020 1:21 pm
Many Thanks!
- Top SketchUcator
- Name: Pilou
by halroach » Wed Jun 17, 2020 2:30 pm
New Flex Bifold component released! Learn more at https://flextools.cc/blog/flex-bifold/
halroach
- License type: Pro
by juju » Wed Jun 17, 2020 2:53 pm
Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Thu Jul 09, 2020 6:20 pm
Hello everyone, we're glad to introduce a new 3 Sash FlexSlider. A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
halroach
- License type: Pro
by halroach » Tue Aug 11, 2020 3:21 pm
New update for ComponentFinder! FlexTools - CF on the toolbar.png A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements! CF screenshot_05.1 - export to toolbar.png More info at the blog: https://flextools.cc/blog/new-component ... -toolbars/If you find this update useful (or not!?) we want to hear you!
halroach
- License type: Pro
by halroach » Sat Aug 29, 2020 6:04 am
We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know. Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8(YT) 10 extensions by Alex Oliver.png
halroach
- License type: Pro
by halroach » Thu Nov 26, 2020 8:21 pm
New Flex Multi Slider released! With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day. Check it out: https://flextools.cc/blog/new-flex-multi-slider/
halroach
- License type: Pro
by halroach » Fri Dec 04, 2020 4:42 pm
Thanks to Justin for the video!
halroach
- License type: Pro
by halroach » Tue Jan 26, 2021 1:48 pm
Have you ever wished you could change default thumbnails with your own, see your rendered images instead of V-ray proxies? You can do that in ComponentFinder now! Assign your own thumbnails with custom images:Right Click > Set Custom Thumbnail > Choose a JPG or PNG ComponentFinder - Set Custom Thumbnails.png The thumbnail image you assign will be automatically copied into the folder where the component is stored, and it will be named with the same name. View in Windows - Custom thumbnails are saved along side the skp files.png Would you find custom thumbnails useful?
halroach
- License type: Pro
by halroach » Thu Feb 04, 2021 4:24 pm
One more new feature in the latest update is the Recently Used tab. You can now reach your recently used components in one click! ComponentFinder - Recently Used Tab.png If you need to find the original folder where a recent component is stored: Right Click > ‘Open Containing Folder in a New Tab’Open containing folder.png Let us know what you think in the comments!
halroach
- License type: Pro
by halroach » Wed Apr 07, 2021 8:43 am
There are 3 things we can watch forever: fire burning, water falling, and speed modeling with FlexTools.  Thanks to Moshe Shemesh for sharing the video.
halroach
- License type: Pro
by halroach » Wed Apr 28, 2021 12:57 pm
Introducing FlexFence! With this one dynamic component you can create roughly 70% of fences and railings out there, both wooden and metal style. Learn more in the blog: https://flextools.cc/blog/introducing-flexfence/
halroach
- License type: Pro
by halroach » Mon May 03, 2021 6:03 pm
Flex Fences (and railings) can be easily joined together: In order to connect two FlexFences to form a corner:1. Place two fences in a 90 degree angle to each other, having them share the location of one of their posts. 2. Hide one of the edge posts by clicking on it with the interact tool or through the options menu. 3. If needed, you can choose to extend the picket positions of each fence to reach the other's post, rail or picket.
-- Let us know what you think!
halroach
- License type: Pro
by halroach » Thu May 20, 2021 8:00 am
Check out Justin's new video about Easy Fencing in SketchUp!
halroach
- License type: Pro
by halroach » Tue Jun 15, 2021 8:36 am
We thought it would be helpful if there was a collection of ready-to-use dynamic fences and railings. So we took some popular fences and railings and recreated them with the FlexFence component! Each Flex Fence example can be customized further to best suit your design, and then saved for later immediate use. Download the collection hereFlexFence - Collection.png What other fences/railings would you like to have dynamic?Send us pictures or skp models of your go-to fence and railing types!
halroach
- License type: Pro
by pibuz » Tue Jun 15, 2021 8:45 am
GIGA thanks!!!!
**EDIT** is there some sort of pre-setting to be choosed before using these DCs? Or is FlexTools PRO needed?
I only use component finder, and using these fences as "common" DCs doesn't work at all for me..
pibuz
- Name: Filippo Scarso
- License type: Pro
by halroach » Wed Jun 16, 2021 9:47 am
Hi Filippo,
Yes, all the fences are examples of the customized FlexFence component, so you will need a FlexPack Pro license for them to work dynamically.
halroach
- License type: Pro
by halroach » Mon Jul 26, 2021 2:07 pm
“I live in 3D and think in 3D and so I find the most efficient way to get that 3D image out of my head and start working with it is to create it directly in Sketchup." – Derek Sallans, Longhouse Design Derek’s workflow for concept design is so fast and intuitive, so very SketchUp-like (and FlexTools-like), we couldn’t help but share it with you!  Check it out: https://flextools.cc/blog/thinking-in-3d-with-sketchup/Thinking in 3D with SketchUp - cover.jpg
halroach
- License type: Pro
by halroach » Wed Aug 11, 2021 4:52 pm
How do you show the swinging direction for your doors and windows in elevation? Pointing to the Right? Or Wrong?
We've always thought of this symbol as a triangular flag with the fixed side where the hinges are and the pointy side where the handle is. However, in some places the flag works the other way around, huh?! As we are now working on a tag (layer) for 2D markings for FlexTools components, we need your advice! Which way do you mark your swings?
halroach
- License type: Pro
- Robot
Return to FlexTools
