Discussions for FlexTools - Responsive Sketchup Modeling
by halroach » Wed Sep 20, 2017 2:48 pm
flexpack 2018_01_02.png FlexTools released! Happy to announce the release of FlexToolsFlexTools is the next generation of the Sketchup Flex dynamic components you may already be familiar with. FlexWindow, FlexDoor, FlexSlat and now a new FlexTrapezoid (more components on the way). This is the best place to write your questions, impressions, anything that's on your mind! Check it out: FlexTools.cc
halroach
- Name: Yoni Frandzel
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by juju » Wed Sep 20, 2017 3:14 pm
I bought my licence for FlexPack moments after the e-mail notification, thank you. Now to start playing with it...
juju
- Premium Member
- Name: Juju
- SketchUp version: 2021
- License type: Pro
by juju » Wed Sep 20, 2017 3:42 pm
Hi FlexTools team (and Yoni)! I quickly tried out the new tools, but seem to be getting something wrong, cutter units are not cutting to the depth specified. See pics below. FlexTools 01.JPG FlexTools 02.JPG I double checked to set the cutting depth the same as the wall, but it only cuts the one face. Tried recalc as well, made no difference. I have Cutting DC's enabled. What gives? Also, how do I set the door frame sizing? I looked at it very quickly, so may have missed it. One other strange thing, inserting the windows and louvres the origin is set to the bottom? I've never placed units with this origin, any way we can get choices for top (middle / left / right)?
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Wed Sep 20, 2017 5:01 pm
Hi Juju  juju wrote:Hi FlexTools team (and Yoni)! I quickly tried out the new tools, but seem to be getting something wrong, cutter units are not cutting to the depth specified. See pics below. I double checked to set the cutting depth the same as the wall, but it only cuts the one face. Tried recalc as well, made no difference. I have Cutting DC's enabled. What gives?
The cutter components cut single faces only! They do however work pretty well with the Double-Cut plugin by Dale Martens - though there are still some issues. Also, how do I set the door frame sizing? I looked at it very quickly, so may have missed it.
Specifically with the door, you have to double-click to enter the inner component which has all the settings. One other strange thing, inserting the windows and louvres the origin is set to the bottom? I've never placed units with this origin, any way we can get choices for top (middle / left / right)?
If I understand correctly, you mean when you first insert a component from the toolbar (or from the manager) that the cursor is placed at the bottom left corner? If that's what you mean, there's not much we can do about that. It's the default behavior of Sketchup when placing components.
halroach
- License type: Pro
by rv1974 » Wed Sep 20, 2017 5:05 pm
My $0.02: you should add a corner L shaped aluminum panel. The example shown in video is not quite right.
rv1974
- Name: rv1974
- SketchUp version: 2017
- License type: Pro
by halroach » Wed Sep 20, 2017 5:10 pm
rv1974 wrote:My $0.02: you should add a corner L shaped aluminum panel. The example shown in video is not quite right.
Not exactly sure what you're referring to. Where should there be an L shaped panel?
halroach
- License type: Pro
by juju » Wed Sep 20, 2017 5:34 pm
halroach wrote:Hi Juju  juju wrote:Hi FlexTools team (and Yoni)! I quickly tried out the new tools, but seem to be getting something wrong, cutter units are not cutting to the depth specified. See pics below. I double checked to set the cutting depth the same as the wall, but it only cuts the one face. Tried recalc as well, made no difference. I have Cutting DC's enabled. What gives?
To my knowledge, the component position w.r.t. the origin determines how the component is placed, not sure if tbis is true for DC's as well.
juju
- Premium Member
- Name: Juju
- License type: Pro
by rv1974 » Wed Sep 20, 2017 9:43 pm
halroach wrote:rv1974 wrote:My $0.02: you should add a corner L shaped aluminum panel. The example shown in video is not quite right.
bending, no grooves in the corners.
rv1974
- Name: rv1974
- License type: Pro
by juju » Fri Sep 22, 2017 10:31 am
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Fri Sep 22, 2017 10:57 am
Not all panel configurations use an L shaped corner - Like the red paneling in this Alucobond example: Thermal_Comm_product_lightbox_800x5744_0000s_0000s_0000_Layer_4.jpg Though I do agree that L shaped corners would be a nice addition to FlexPanel!  FlexPanel can be used for all sorts of other repetitive paneling situations like: floors, interior walls, even basic cabinetry situations where you don't want to start messing with a real cabinet components. Still working on it...
halroach
- License type: Pro
by halroach » Fri Sep 22, 2017 11:12 am
juju wrote:To my knowledge, the component position w.r.t. the origin determines how the component is placed, not sure if this is true for DC's as well.
I understand now what you mean. There are two situations to consider: 1. When a component is placed into a model 2. A copy paste situation. In the first situation, yes, components are placed according to their main Axis, which in the Flex DCs is the bottom left corner. I could theoretically design them to change the main axis, but it would probably add a lot of calculations that would give them a slower refresh time. We don't want that! Also, thanks to SketchUp's super duper inferencing, selecting, moving, re-positioning one or a bunch of windows is really quite quick. I wouldn't want to mess up the code for something that is really easy to do in Sketchup. 2. In copy paste situations, in most cases the placement is from the bottom left corner, no matter where the component axis is located. So we're keeping the experience quite consistent this way.
halroach
- License type: Pro
by halroach » Fri Sep 22, 2017 11:13 am
juju wrote:The DC's work with [url=http://extensions.sketchup.com/en/content/face-cutter]Face Cutter[/url] ($3.99) as well.
Good to know!  *** Hmmmm, Just tried it out - seems a bit buggy when copying and pasting components around. If you pull in new components straight from the toolbar it's fine.
halroach
- License type: Pro
by juju » Fri Sep 22, 2017 11:50 am
halroach wrote:juju wrote:The DC's work with [url=http://extensions.sketchup.com/en/content/face-cutter]Face Cutter[/url] ($3.99) as well.
I didn't try that initially, but have now. When doing a CTRL+C & CTRL+V it seems to work fine with the louvres (which have no cills), the windows work depends on where the insert point / position is (cills are a problem) and the door seems to go completely awry. When doing a shift + move (which equates to copy and move with the native tools) it works on my end.
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Thu Oct 05, 2017 11:03 am
Components Update!
Thanks to your input, we found an issue with the face-cutter versions of all 4 Flex components. The components in this update fix the issue. After updating, you will be able to set the wall thickness independently. (It is not affected by the frame depth, or by the inset settings anymore).
Important Note In the favorites manager - Only the 'Original' components are updated. Previously saved favorites remain untouched in their current versions.
How to get the update An automatic update is available from within the plugin! 1. Open the FlexTools manager (cog icon) 2. Click on the red Update button at the top of the window. 3. A restart of Sketchup may be required.
The updated Flex Component versions: FlexDoor 1.3.25 FlexWindow 2.5.36 FlexTrapez 1.1.53 FlexSlat 1.2.06
Want to make sure you have the latest versions? Click on each component's settings icon in the components manager
halroach
- License type: Pro
by halroach » Thu Oct 19, 2017 11:23 am
Existing customers! One day left to get 30% Off all FlexTools products. (Details will arrive by email).
halroach
- License type: Pro
by halroach » Thu Dec 14, 2017 4:04 pm
flexpack 2017_05-flexpanel_04_release.jpg FlexPanel is finally here!You can now create all sorts of orthogonal panels, cladding, tiles, walls, floors, ceilings… in just a few clicks! And as usual with Flex components with Responsive Scaling, the panels fit exactly where you need them. - Full control over panel thickness, spacing and distributions.
- Set the number of panels to be equally distributed, or set a fixed size, and let FlexPanel complete the remainders.
- Choose between 6 edge extensions, for when you want to align a few panel systems - side by side, or around a corner.
- Cutter version, for when you want to embed panels to be flush with the face they are placed on.
Click to see animationflexpanel_animation_05_01.gif Click to see animationflexpanel_animation_06_01e.gif How to get FlexPanel?Check out FlexToolsIf you already have FlexPack 2017 installed, you can start using it now! All you need to do, is to open the FlexTools Manager and click on the red update button. Happy Flexing!
halroach
- License type: Pro
by Daria C137 » Mon Apr 02, 2018 2:50 pm
 Open / Close multiple FlexDoors at once
1. Make a selection. 2. Run the Open/Close tool - any FlexDoors included in the selection will either open or close. If there are more 'open doors' than 'closed doors' in the selection, all the doors will be closed.
Daria C137
- Name: Daria Frandzel
- License type: Pro
by Daria C137 » Mon Apr 09, 2018 3:43 pm
The entire UI of the plugin and all the components and tools, can be displayed in different languages. Currently FlexTools for SketchUp can be used in: ⭐️English ⭐️Spanish ⭐️French ⭐️Portuguese ⭐️Traditional Chinese and ⭐️Simplified Chinese! We are very proud of our translation system, since it also works retroactively! All Flex components previously used, and saved in the Favorites Library will also be automatically translated.
Special thanks to those who contributed their precious time and expertise: If you wish to contribute a translation in your own language, please contact us: https://flextools.cc/contact/#WriteUs
Daria C137
- License type: Pro
by halroach » Tue May 15, 2018 9:52 am
We just launched a beta version of ComponentFinder. Hooray! Looking for people to help us test and improve it. Be part of it! --> https://flextools.cc/componentfinder-beta/And yes, it’s FREE!
halroach
- License type: Pro
by juju » Mon Jun 04, 2018 9:20 pm
Yoni, any chance we can get an option with the doors to have the door swing also show when the doors are closed? I keep on configuring the door and explode the component, rotate the door to the closed position and draw a missing line (door leaf in open position).
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Wed Jun 06, 2018 3:33 pm
juju wrote:Yoni, any chance we can get an option with the doors to have the door swing also show when the doors are closed? I keep on configuring the door and explode the component, rotate the door to the closed position and draw a missing line (door leaf in open position).
Hi Juju, I imagine you need this for presenting plans? Can you post an image or a model of what the end product should look like? I think I understand, but just to make sure.
halroach
- License type: Pro
by juju » Wed Jun 06, 2018 9:22 pm
halroach wrote:I imagine you need this for presenting plans? Can you post an image or a model of what the end product should look like? I think I understand, but just to make sure.
That would be correct, needed when creating construction documentation. When using parallel projection with section cut (I use Skalp) the doors appear correct on plan, and the elevations as well with my work-around. The doors would normally appear correct on plan in the current open setting, however on parallel projection elevation one would want these closed, but when you close the doors to get the elevations looking correct you lose the door swing representation in plan again. Also the current method I'm using isn't ideal because I need to spend a little extra time per door to do this, plus I lose the dynamic component / interactive part thereof since I'm exploding it and manually rotating to the closed position. I suppose I could just copy / paste the swing and draw the extra line representing the door in the open position, but if it could be done automatically it would be a great help. I can imagine there may be times when you would not want the door swing representations, thus if it could be an optional on/off for this it'd be great. Of course if one could customize / name the layer where you would this 2D swing / open door representation to be placed (as well as the glazing & framing) it would be the ultimate, but this will probably remain a pipe dream for now. But hey, it never hurts to ask / put it out there.
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Thu Jun 07, 2018 12:50 pm
Hey Juju, Please see the attached FlexDoor. It has an extra option under the 'Arc:' attribute called "Always ON". When you want to turn it off, you may need to open and close the door once to see the changes. It's not perfect, but it's way better than exploding! flex_door_ft_1.6-arc always on option - Juju.skp Regarding layers: The arcs are on a separate layer called FlexDoor_Arc. You can always change it's name to what ever you want and then save the component to a folder in ComponentFinder (now officially released as part of FlexTools!). Hope this helps,
halroach
- License type: Pro
by juju » Thu Jun 07, 2018 4:21 pm
halroach wrote:Hey Juju, Please see the attached FlexDoor. It has an extra option under the 'Arc:' attribute called "Always ON". When you want to turn it off, you may need to open and close the door once to see the changes. It's not perfect, but it's way better than exploding! flex_door_ft_1.6-arc always on option - Juju.skp Regarding layers: The arcs are on a separate layer called FlexDoor_Arc. You can always change it's name to what ever you want and then save the component to a folder in ComponentFinder (now officially released as part of FlexTools!). Hope this helps,
Hi Yoni, thanks for this. Will you be making this part of the sets that comes with your extension by default?
juju
- Premium Member
- Name: Juju
- License type: Pro
by halroach » Thu Jun 07, 2018 5:55 pm
Hey Juju, Sure, we'll do our best to add this feature in the next update, or the next after that... In the mean time you can add this component to any folder on your hard disk, and have quick access to it through ComponentFinder.
If you want to change the default component that loads from the toolbar, you can replace the default door with this one. Make sure the new component has the same name => "flex_door_ft_1.skp". (Make a backup of the old one, just in case...)
C:\%ProgramData%\F3d_FlexTools\packages\components\flex_door_ft_1\component
halroach
- License type: Pro
by halroach » Mon Jul 09, 2018 11:25 am
Big news! The following new additions that we are working on will be part of the new package called FlexPack Pro! - WallCutter
- Slider Window
- Double-Hung Window
- Awning and Hopper Windows
- Casement Window
- ComponentFinder improvements
Read more on our blog: https://flextools.cc/blog/flexpack-pro/
halroach
- License type: Pro
by halroach » Mon Jul 30, 2018 5:27 pm
The first update for FlexPack Pro: WallCutter is released, and it cuts through walls like never before! Check it out! >> https://flextools.cc/wallcutter
halroach
- License type: Pro
by halroach » Mon Aug 13, 2018 8:35 am
A quick update: We released a few enhancements and important bug fixes for WallCutter and the Place Upright tool. Read more about the changes in the Change log: https://flextools.cc/change-log
halroach
- License type: Pro
by dpaul » Mon Aug 13, 2018 8:42 pm
Hello, Is it possible to use a window/door component with casings on BOTH sides and only the FRAME of the win/door cuts the wall (a group), leaving the trim on both sides intact? With my thanks. David
dpaul
- Premium Member
- Name: D. Paul
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
by halroach » Tue Aug 14, 2018 6:37 pm
dpaul wrote:Hello, Is it possible to use a window/door component with casings on BOTH sides and only the FRAME of the win/door cuts the wall (a group), leaving the trim on both sides intact? With my thanks. David
Hey David, Yes it is possible... But we haven't released this feature yet.  . It will be available in the next update of FlexTools. You will then be able to mark sub-components to be ignored by the cutting algorithm. We'll make an announcement when it's ready. Yoni
halroach
- License type: Pro
- Robot
Return to FlexTools
