FlexSlat FT 1.2 orientation & construction points
Discussions for FlexTools - Responsive Sketchup Modeling
Postby optimaforever » Fri Sep 01, 2017 3:20 pm
I love FlexSlat and I often use it to quickly model railings.
1. Is it possible to have a quick parameter to make the slats vertical? By default they are horizontal and I always rotate manually the component to create vertical poles.
2. In order to place the poles precisely when I don't want a frame around it, I wether keep a dummy frame and when correctly placed, I change the frame size to 0x0, wether I use the script "add construction points to the bounding box corners". This is a generic topic but is it possible to have these construction points generated by default? I mean, a bounding box usable by the SU default inferences?
optimaforever
Premium Member
Premium Member
Re: FlexSlat FT 1.2 orientation & construction points
Postby halroach » Fri Sep 01, 2017 7:23 pm
1. I think if I do that, it may make the component heavier, and may make the interface more complicated. If it were a separate component?
halroach
Postby halroach » Fri Sep 01, 2017 7:26 pm
2. Try the "frame guide" setting. Does that help?
halroach
Return to FlexTools
