Welcome to FlexTools Beta
Discussions for FlexTools - Responsive Sketchup Modeling
Postby halroach » Mon Aug 28, 2017 1:48 pm
Welcome to the FlexTools beta battle grounds!
This is the place to write comments, issues, bugs, suggestions, about anything that hasn't been released yet:
  • The FlexTools plugin
  • Dynamic Components
  • Tools
Feel free to repeat stuff you've written in personal emails if you think it will help.
Yoni & Max
[2017-08-29] Release v1.1.0
New
  • New Planview tool
Fixes
  • Flex components would not work in certain Sketchup loading situations. Fixed!
New
  • 'Presets' are now named 'Favorites'.
  • Added 'Add to favorites' button - Appears on toolbar and in favorites window.
  • Added Favorites search.
Improvements
  • Safer observers.
  • Loading time of the plugin optimized.
Fixes
  • Fixing crashing observers in OSX.
  • Product activation on OSX won't require SketchUp restart anymore.
Possible Issues
  • When FlexTools and Double-Cut plugin are both installed - In some situations upon closing Sketchup, a Sketchup crash message may appear. It's harmless. Please let us know if this happen to you too.
[2017-08-29] FlexBundle 1.2.3
Fixes
Small unnoticeable fix to FlexDoor
halroach
Re: Welcome
Postby Rich O Brien » Mon Aug 28, 2017 1:50 pm
Let the battle commence ;)
All of us at sketchUcation are wishing you the best with your new tool! :thumb:
Rich O Brien
Administrator
Re: Welcome to FlexTools Beta
Postby esterkimx » Mon Aug 28, 2017 3:26 pm
Hi! Report any issues you have with the FlexTools plugin - I'll be glad to fix them.
Adding your operating system, SketchUp version and other extra information would be of great help.
I hope our plugin will improve your workflow :-)
-1
esterkimx
Postby optimaforever » Mon Aug 28, 2017 3:49 pm
esterkimx wrote:I hope our plugin will improve your workflow :-)
Hello, thanks for creating this forum.
yes, flextools are already improving (a lot) my workflow. I'll post all the ideas I chatted about with Yoni here soon...
optimaforever
Premium Member
Premium Member
Postby rafiky » Tue Aug 29, 2017 10:30 am
Thanks for let us to help you and improve the tool. Flextools is very useful!
rafiky
Postby halroach » Fri Sep 01, 2017 10:58 am
Thank you Rich for helping us out with this forum!
Glad FlexTools is helping you guys :).
New FlexTools v1.1.0 beta is out! (See first post above)
The main highlight:
  • Add to favorites button
  • Search through favorites!!!
Have a nice beta weekend ;)
halroach
Postby pilou » Fri Sep 01, 2017 6:12 pm
Cool! :fro:
No top Arc Circles Windows?
When you input a false degre inside a FlexTrapez that explode the model!
Speedy Galerie
Top SketchUcator
Postby halroach » Fri Sep 01, 2017 7:35 pm
So don't put a false degree? ;).
I might be able to limit from false degree input... I'll need to sit and think about it.
If you enter a normal degree it goes back to normal?
halroach
There will be a circular window!!! :fro:
halroach
Postby pilou » Sat Sep 02, 2017 12:00 am
Yes! :enlight:
Speedy Galerie
Top SketchUcator
Postby halroach » Sun Sep 03, 2017 4:35 pm
1. FlexTools updated to v1.1.1 beta (See first post above)
The main highlights:
  • New Planview tool to play around with :D
  • Bugfix
halroach
Postby rafiky » Wed Sep 13, 2017 10:54 am
Hi!
I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, alwais remain the old wall thickness.
The only way to solve it is changing the inset value and it works but not the first time you change the wall thickness.
Cheers,
P.D. Sorry for my english.
rafiky
Postby halroach » Wed Sep 13, 2017 11:52 am
rafiky wrote:Hi!
I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, always remain the old wall thickness.
I'm not sure, but it seems like it's working fine :).
There are 4 thickness/depth settings that may need changing to get which ever wall thickness and desired placement you need:
Frame Depth / Wall Thickness / Inset / (Doorstop)
Currently:
1. The Frame can be any size you want, and it's placement, in relation to the wall (together with all the other door elements) is determined by the Inset value.
2. The wall thickness is determined by either the thickness you give it - OR - the sum of the frame depth + inset value. If the sum of frame depth and inset are larger than then the wall thickness, the wall get's thicker...
The reason is, that if the inset were deeper than the wall thickness, you'd have a floating door/window. Unless that's what you want!?
halroach
Postby rafiky » Wed Sep 13, 2017 12:57 pm
rafiky
Postby halroach » Wed Sep 13, 2017 1:14 pm
Ok, I think that's the doorstop depth that needs adjusting.
Currently the doorstop is positioned according to the door panel thickness, and extrudes according to the input value. After you adjusted the frame the doorstop is just too long.
Maybe the calculation should be different? like maybe a minus value from the frame edge?
halroach
Postby rafiky » Wed Sep 13, 2017 6:26 pm
I don't think so. Only changing the inset value from 0 to 0,00 on the first options it works.
rafiky
Postby halroach » Wed Sep 13, 2017 6:28 pm
Can you send me the model when it's acting odd?
halroach
Postby rafiky » Wed Sep 13, 2017 7:32 pm
here it is
rafiky
Postby halroach » Wed Sep 13, 2017 7:47 pm
rafiky wrote:here it is
Ok, now I see the problem. I must have done something wrong with the wall thickness calculation. If the frame is thicker than the wall, then the wall doesn't change, which is not right. I'll need to fix that!
Thanks man!
halroach
Postby halroach » Thu Oct 05, 2017 11:06 am
Fixed the wall thickness issue!
Please see the post on the main thread:
halroach
Return to FlexTools
cron
