FlexTools Updates
Discussions for FlexTools - Responsive Sketchup Modeling
Re: FlexTools Updates
Postby mogren » Tue May 12, 2020 12:36 pm
Exemple
User avatar
mogren
Postby pilou » Tue May 12, 2020 1:43 pm
Hospices imaginaires ou ayant existés ?
Speedy Galerie
User avatar
Top SketchUcator
Postby mogren » Tue May 12, 2020 1:56 pm
pilou wrote:Hospices imaginaires ou ayant existés ?
Décor film
User avatar
mogren
Postby halroach » Tue May 12, 2020 4:42 pm
mogren wrote:What I would like :enlight:
You should be able to get that with the following settings.
'Inset' to move the window in/out in relation to the wall.
'Frame - Depth' to get it as deep as you need.
Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
User avatar
halroach
Postby mogren » Tue May 12, 2020 9:07 pm
To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
User avatar
mogren
Postby pilou » Tue May 12, 2020 10:59 pm
Je crois que oui, c'est ce qui était décrit dans les posts précédents ;)
Il faut utiliser 2 composants l'un dans l'autre!
I took two arch components, and placed one in the other.
Speedy Galerie
User avatar
Top SketchUcator
Postby mogren » Wed May 13, 2020 10:32 am
pilou wrote:Je crois que oui, c'est ce qui était décrit dans les posts précédents ;)
Oui effectivement pardon j'ai posé la question trop vite
User avatar
mogren
Postby mogren » Wed May 13, 2020 10:35 am
Ceci dit l'idéal n'est pas encore là
User avatar
mogren
Postby pilou » Wed May 13, 2020 11:44 am
I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby halroach » Wed May 13, 2020 12:20 pm
pilou wrote:I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! ;)
Updated to 2017!
User avatar
halroach
Postby pilou » Wed May 13, 2020 1:21 pm
Many Thanks! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby halroach » Wed Jun 17, 2020 2:30 pm
New Flex Bifold component released!
Learn more at https://flextools.cc/blog/flex-bifold/
User avatar
halroach
Postby juju » Wed Jun 17, 2020 2:53 pm
Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
User avatar
juju
Premium Member
Premium Member
Postby halroach » Thu Jul 09, 2020 6:20 pm
Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
User avatar
halroach
Postby halroach » Tue Aug 11, 2020 3:21 pm
New update for ComponentFinder!
A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
More info at the blog: https://flextools.cc/blog/new-component ... -toolbars/
If you find this update useful (or not!?) we want to hear you!
User avatar
halroach
Postby halroach » Sat Aug 29, 2020 6:04 am
We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
User avatar
halroach
Postby halroach » Thu Nov 26, 2020 8:21 pm
New Flex Multi Slider released! :bounce:
With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
Check it out: https://flextools.cc/blog/new-flex-multi-slider/
User avatar
halroach
Postby halroach » Fri Nov 27, 2020 5:23 pm
We haven't done any promotions for a whole year, but hey, today is Black Friday! :D
:arrow: https://flextools.cc/black-friday/
User avatar
halroach
Postby halroach » Fri Dec 04, 2020 4:42 pm
Thanks to Justin for the video!
User avatar
halroach
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to FlexTools
cron
Who is online
Visit our sponsors:
