Bug in Apparition Movement
General discussion about Animator for SketchUp
Postby xxxnova » Fri Mar 13, 2020 4:27 am
Hi Fredo,
I've found some bugs, that annoy so much.
I've only select one object that would be assigned with apparition movement,
But other object with same shape who not selected are applied with this apparition too automatically, i just need this apparition only work on my selected object.
Is this just occurred only on my Animator?
Would be great if this problem was solved.
xxxnova
Re: Bug in Apparition Movement
Postby fredo6 » Fri Mar 13, 2020 9:56 am
xxxnova wrote:Hi Fredo,
It's probably because your object is a component instance which is itself embedded in another component instance which exist in several copies in the model.
In Sketchup, can you modify your object manually, say add a line, and see what happens to the rest of the model.
anyway, posting the model would help.
Fredo
fredo6
PluginStore Author
PluginStore Author
Return to Animator Beta
Users browsing this forum: No registered users and 4 guests
