Animator - V-Ray Next
• Page 1 of 1
Animator - V-Ray NextI am sucessfullly animating a scene using Animator, however, when selecting the V-Ray rendering function the animation output is "still" at the point of the initial camera location. I'm using SketchUp Pro 2019 and V-Ray Next on Mac OS....any ideas on how I can rectify, thank you.
Re: Animator - V-Ray NextChrisHendo,
I am having the same problem on Sketchup Pro 2018 and V-Ray Next Build 4.20 on PC. Did you find the cause of the problem? Thanks, Jack Re: Animator - V-Ray NextI seem to recall the animator plugin isn't compatible with the latest version of Vray.
Re: Animator - V-Ray NextOK thanks, I will try a different installation to see if there is any change
Re: Animator - V-Ray NextI just installed VRay v4.2 and can confirm the problem: VRay ignores the movement of objects and just render a sequence of the same original scene.
I am contacting Chaos Group to find out. Fredo
Re: Animator - V-Ray NextThe problem with VRay 4.2 rendering should be fixed with LibFredo6 v10.9a.
Thanks to report if this works for all of you. Fredo
• Page 1 of 1
