Moving a 3D figure along a Bezier curve
• Page 1 of 1
Moving a 3D figure along a Bezier curveIs there a way to keep a 3D Figure parallel to the global Z-axis when moving along a spiral curve created as a Bezier curve? My figure rotates as it moves along the curve.
Re: Moving a 3D figure along a Bezier curve
In your model, you should create a Movement "Follow Path". - Select the character - Select the path - Make sure that - Reverse direction is checked (because your curve in going top to down) - Object rotation is unchecked (to keep the guy upright)
• Page 1 of 1
