General discussion about Animator for SketchUp
by fredo6 » Sun Jan 12, 2020 2:26 pm
FFmpeg is an open source program of the foundation FFmepg.org providing a comprehensive set of methods to manipulate images and videos. Animator uses FFmpeg to stitch the set of images generated for each frame of an animation into a video with various format. If you do not install FFmpeg, Animator will only generate the animation as a sequence of images. This post indicates where to download FFmpeg from and then how to install it so that it can be used by Animator. Step 1 - Downloading FFmpegThe first step is to download the FFmpeg executable. The links below point to a zip file containing the executable file of FFmpeg (stored on the Sketchucation web site). Step 2 - Extracting FFmpeg executableThe second step is to extract the FFmpeg executable from the ZIP archive you just downloaded. 1) Open the Zip file (with 7-Zip program or equivalent). Note for Mac users: You may need to authorize FFmpeg for your Mac. Go to the Security panel (menu Apple > System Preferences > Security and Privacy > General). 2) Copy the file ffmpeg.exe (or ffmpeg for Mac) to a safe place on your computerJust make sure you remember where you put the file on your computer.The best is to copy the FFmpeg executable to a location that is independent from the current Sketchup version. Note: If you put the FFmpeg executable in the following directories, the location will be automatically recognized by Animator, and you can skip Step 3 below: - On Windows: C:\FFmpeg\
- On Mac: ~/Applications
Step 3 - Locating FFmpeg within AnimatorIf you did not install and locate FFmpeg on your computer and you try to generate a video with Animator, you will get the following flavor of the dialog box for generating videos: Animator Video NO FFmpeg.png FFMpeg 2 buttons.png The button How to get FFmpeg? opens the present post on Sketchucation. The button Find FFmpeg program? is used to locate the FFmpeg executable on your computer, after you performed Step 1 and Step 2. Once Animator knows where the FFmpeg program is located, then you will go directly to the normal flavor of the dialog box, allowing you to generate videos files in various formats. Animator Video WITH FFmpeg.png Note that you can still change the location of FFMpeg executable with the button FFmpeg on the right of the dialog box.
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Intermediate
by jstahlman » Wed Sep 23, 2020 8:23 am
The download link is not working. I found a version that works here https://ffmpeg.org/download.html#build-mac
jstahlman
- Operating system: Mac
- SketchUp version: 2016
- License type: Pro
- SketchUp use: illustration, cartoons
- Level of SketchUp: Advanced
by fredo6 » Wed Sep 23, 2020 12:56 pm
Thanks for signaling. It seems that the hosting site Zeranoe has closed on 18 Sep 2020. There seems to be alternative sites. I'll check and update the documentation. Fredo
- Name: Fredo6
- License type: Pro
by kimga » Thu Oct 22, 2020 12:01 pm
Thank you very much for the ANIMATOR and for the FFmpeg.
I am just trying to generate my first video, but after completing all the instruction bove I still only get a folder with images instead of a video in the selected format.
I downloaded the latest WINDOW compatible FFmpeg, unzipped, copied the ffmpeg.exe to the PLUGIN folder and located it within ANIMATOR. Then I restarted the computer. After all that I tried to generate the video I already set up before all this process. It showed the pictures and a text file in the folder, but when I pressed save and exit the images did disappear and the only thing left is an "FFmpeg_log_mp4" file.
Any suggestions, what could have gone wrong, please? Cheers
kimga
- Name: Kinga SWAIN
- License type: Pro
- SketchUp use: film and stage
by fredo6 » Thu Oct 22, 2020 7:44 pm
Strange...
Did you regenerate the video after you installed FFmpeg?
- Name: Fredo6
- License type: Pro
by kimga » Tue Oct 27, 2020 7:24 pm
I tried and tried over the last week. Re-installed the plugin many times, restarted the computer and set up a new film and movement.
Unfortunately, the outcome is the same. The window shows all the possible formats once the FFmpeg file is located. Starts to generate the imagines into the folder. And at the end, when pressing the "save and finish" - or something similar on the bottom-right corner of the window, all the image files would disappear from the folder, no video is created at all and only the above mentioned txt file left behind....
Couldn`t figure what can be the problem.
I am planning to buy a new computer, workstation for Christmas. I will try if it works then.
Thank you for trying to help. Cheers,
kimga
- Name: Kinga SWAIN
- License type: Pro
by fredo6 » Wed Oct 28, 2020 10:05 am
@kimga
At the end of the generation, do you see a 'black' window appearing for a few seconds (this is the FFmpeg video stitching).
Also, in the folder, there is a text file, FFmpeg_log.text. Could you look into it and see there is an error, or post it here or PM it to me.
- Name: Fredo6
- License type: Pro
by cleatus269 » Fri Oct 30, 2020 4:27 pm
i get the same error. i can navigate to the folder while the video is generating and see the images stacking up, but once it completes the render and i hit save and exit, the ENTIRE folder is empty. no txt files, no images, nothing. just an empty folder and another 2hrs wasted... please help. i have already missed my deadline once and would like to meet the next one.
thanks
cleatus269
- Name: Chase lackey
- License type: Pro
- SketchUp use: architecture
by sistemasIPS » Sat Oct 31, 2020 7:30 pm
What is the updated link to download the file corresponding to win64?
sistemasIPS
- Name: sistemasIPS
- SketchUp version: 2020
- License type: Pro
- SketchUp use: education
by sistemasIPS » Sat Oct 31, 2020 8:49 pm
After successfully installing (I think) the ffmpeg, I get an error when exporting, in any format: "error in the video file generation"
This is the file that the program generates:
ffmpeg version n4.3.1-20-g8a2acdc6da Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3-win32 (GCC) 20200320 configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-gpl --enable-version3 --disable-debug --enable-iconv --enable-zlib --enable-libxml2 --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-opencl --enable-libvmaf --disable-vulkan --enable-libvorbis --enable-amf --enable-libaom --enable-avisynth --enable-libdav1d --enable-libdavs2 --enable-ffnvcodec --enable-cuda-llvm --disable-libglslang --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librav1e --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libtwolame --enable-libvidstab --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libzimg --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-libs=-lgomp libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [image2 @ 000001cab0794640] Could find no file with path 'Image%02d.png' and index in the range 0-4 Image%02d.png: No such file or directory
sistemasIPS
- Name: sistemasIPS
- License type: Pro
by PeterThistle » Mon Nov 02, 2020 11:52 am
I am having a similar issue as the above, after following the instructions I am only getting a Text Document named 'FFmpeg_log_mp4'
Below is the what is in the text file, any help would be great thanks!
ffmpeg version N-99816-g3da35b7cc7 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3-win32 (GCC) 20200320 configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-version3 --disable-debug --enable-iconv --enable-zlib --enable-libxml2 --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-opencl --enable-libvmaf --disable-vulkan --enable-libvorbis --enable-amf --enable-libaom --disable-avisynth --enable-libdav1d --disable-libdavs2 --enable-ffnvcodec --enable-cuda-llvm --disable-libglslang --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librav1e --disable-librubberband --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libsvtav1 --enable-libtwolame --enable-libuavs3d --disable-libvidstab --disable-libx264 --disable-libx265 --disable-libxavs2 --disable-libxvid --enable-libzimg --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-libs=-lgomp libavutil 56. 60.100 / 56. 60.100 libavcodec 58.112.100 / 58.112.100 libavformat 58. 64.100 / 58. 64.100 libavdevice 58. 11.102 / 58. 11.102 libavfilter 7. 88.100 / 7. 88.100 libswscale 5. 8.100 / 5. 8.100 libswresample 3. 8.100 / 3. 8.100 Input #0, image2, from 'Image%03d.png': Duration: 00:00:34.04, start: 0.000000, bitrate: N/A Stream #0:0: Video: png, rgb24(pc), 1916x929 [SAR 3780:3780 DAR 1916:929], 25 fps, 25 tbr, 25 tbn, 25 tbc Unknown encoder 'libx264'
PeterThistle
- Name: Peter Smith
- License type: Pro
- SketchUp use: engineering and mechanical design
by fredo6 » Mon Nov 02, 2020 7:12 pm
PeterThistle wrote:I am having a similar issue as the above, after following the instructions I am only getting a Text Document named 'FFmpeg_log_mp4'
Did you install a recent version of FFmpeg? or which date and version (maybe, on the contrary, it is too recent). For whatever reason, it seems to disable the encode which is precisely needed for MP4 file.
- Name: Fredo6
- License type: Pro
by PeterThistle » Tue Nov 03, 2020 10:03 am
fredo6 wrote:PeterThistle wrote:I am having a similar issue as the above, after following the instructions I am only getting a Text Document named 'FFmpeg_log_mp4'
Thanks for your help so far The zip file I extracted the FFmpeg.exe from was "ffmpeg-N-99818-g993429cfb4-win64-lgpl" after re-downloading and extracting it I now see all the stills in the animator videos file, the black window does appear at the end of the the generation but I am still getting just a text file in the animator video file. I don't know if it's different from before but below is what is in the file... ffmpeg version N-99818-g993429cfb4 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3-win32 (GCC) 20200320 configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-version3 --disable-debug --enable-iconv --enable-zlib --enable-libxml2 --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-opencl --enable-libvmaf --disable-vulkan --enable-libvorbis --enable-amf --enable-libaom --disable-avisynth --enable-libdav1d --disable-libdavs2 --enable-ffnvcodec --enable-cuda-llvm --disable-libglslang --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librav1e --disable-librubberband --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libsvtav1 --enable-libtwolame --enable-libuavs3d --disable-libvidstab --disable-libx264 --disable-libx265 --disable-libxavs2 --disable-libxvid --enable-libzimg --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-libs=-lgomp libavutil 56. 60.100 / 56. 60.100 libavcodec 58.112.100 / 58.112.100 libavformat 58. 64.100 / 58. 64.100 libavdevice 58. 11.102 / 58. 11.102 libavfilter 7. 88.100 / 7. 88.100 libswscale 5. 8.100 / 5. 8.100 libswresample 3. 8.100 / 3. 8.100 Input #0, image2, from 'Image%03d.png': Duration: 00:00:34.04, start: 0.000000, bitrate: N/A Stream #0:0: Video: png, rgb24(pc), 1632x929 [SAR 3780:3780 DAR 1632:929], 25 fps, 25 tbr, 25 tbn, 25 tbc Unknown encoder 'libx264'
PeterThistle
- Name: Peter Smith
- License type: Pro
by fredo6 » Tue Nov 03, 2020 2:01 pm
@PeterThistle I don't know what's going on with the recent versions of FFmpeg, but some seem to not include the right codec libraries. Apparently this is the case with the zip file you downloaded. Could you try this one, which is with Full libraries at this link. I tested it on my laptop Win10-6 and it works. The file size of FFmpeg.exe is 105 Mb. https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-full.7zMore generally there is a mess in how the builds of FFmpeg are now released. I cannot find older versions. I need to have a closer look to how to have robust instructions. Fredo
- Name: Fredo6
- License type: Pro
by jayhuss9 » Thu Nov 19, 2020 5:03 pm
i am only getting a mp4.txt file once animating my video. any ideas how i can get the mp4 will be much appreciated.
jayhuss9
- Name: jason husselbee
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Beginner
by fredo6 » Thu Nov 19, 2020 6:52 pm
See the post just above. It may depend on which version of FFmpeg you downloaded.
- Name: Fredo6
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Animator Beta
