General discussion about Animator for SketchUp
by fredo6 » Fri May 28, 2021 8:23 pm
New Release: Animator - v3.5a - 28 May 21Requirement: LibFredo6 v11.5Maintenance release- Bug fixing
- Extension of validity
_______________________________________________________________________________________ See plugin home page of Animator for Download of RBZ from the PluginStore. See Main Post of the Animator thread for more information.
fredo6
- Premium Member
- Name: Fredo6
- Operating system: Windows
- License type: Pro
- SketchUp use: interior design
by solo » Fri May 28, 2021 8:46 pm
Fredo, does Animator work with the new Vray Vision?
solo
- Global Moderator
- Name: solo
- SketchUp version: 2017
- License type: Pro
- SketchUp use: other
by fredo6 » Fri May 28, 2021 10:26 pm
solo wrote:does Animator work with the new Vray Vision?
I don't know. What is VRay Vision?
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by solo » Fri May 28, 2021 11:05 pm
fredo6 wrote:solo wrote:does Animator work with the new Vray Vision?
V-Ray Vision is a real-time viewer that can be used in any project set up for V-Ray rendering. It is a lightweight “game engine” (rasterizer) that does not currently use any type of ray-tracing.
solo
- Global Moderator
- Name: solo
- License type: Pro
by duanekemp » Thu Jun 17, 2021 11:41 am
I'm having serious issues with completing a simple animation. The SketchUp output was fine, though it took over three hours to render 10 seconds at HD720. Doors Animation SU test.mov But, while using Thea Render, every render export keeps crashing around the three second mark. At 25 fps, Windows posts a message that there's no more space around the 74th to 79th image in the sequence, which crashes the process and SU With the Render window stuck. Doors Animation SU Thea test 01 Crash 03.mov Yesterday, I cleared out 60GB of programs from the C Drive in case that's where the memory was being "stored" or created, but, that wasn't the solution as it crashed again. It's a simple camera move and sliding door animation. What could be possibly going on? Could it be the Thea Render Temp file location not having enough space? Could it be the D: drive data folder (where the SU file and image are being compiled) having not enough space? Is there an explanation as to why the animation export is creating such a huge memory block somewhere? At over three hours per test/crash, this is two days trying to get to the end of a 10 second test and I'm being terribly surprised as to how others are able to get 2 minutes of video. So, what am I doing wrong?
duanekemp
- Name: Duane Kemp
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by fredo6 » Thu Jun 17, 2021 12:16 pm
Did you try the rendering with Thea from Thea itself (instead of launching the generation from Animator)?
Normally, the requirements for disk is to have enough space to store the image files, one per frame. Do you have the size of a single image?
For memory, I think this is more related to Thea. Animator and Sketchup do nothing special during the generation in term of memory usage.
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by duanekemp » Thu Jun 17, 2021 12:21 pm
Because Animator exports .png files... the image size is larger than a .jpg (which would be preferable) and so, each image is around 1.46 MB. But, now you have me curious... How does Thea know the path and animation created in Animator in order to render the same animation from Thea? Ah... hadn't tried the Thea animation tool (Animator plugin). Giving this a go in Thea V3: http://kb.thearender.com/thea-for-sketchup-v15/export-animation-studio/
duanekemp
- Name: Duane Kemp
- License type: Pro
by fredo6 » Thu Jun 17, 2021 2:56 pm
duanekemp wrote:But, now you have me curious... How does Thea know the path and animation created in Animator in order to render the same animation from Thea?
The Thea team was kind enough to integrate Animator in their list of animation programs, based on an API I provided to them. duanekemp wrote:Ah... hadn't tried the Thea animation tool (Animator plugin).
Tell me if it works better...
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by duanekemp » Thu Jun 17, 2021 7:17 pm
Tell me if it works better...[/quote] So far, it's rendering but not exporting the renders to the folder. For a moment, I thought this was going to be the solution.
duanekemp
- Name: Duane Kemp
- License type: Pro
by duanekemp » Thu Jun 17, 2021 7:27 pm
JQL wrote:Thanks for providing this solution so fast!
I will resume my endeavours with animator asap!
@JQL, have you used this plugin since Thea Render V3 came out?
duanekemp
- Name: Duane Kemp
- License type: Pro
by tiquibachaaaaa » Sun Jun 27, 2021 4:51 pm
I have a problem while animating. I press the play but it doesn't show the movements, the only way it shows is when I open the window for export images and press the play button.
tiquibachaaaaa
- Name: fran
- Operating system: Mac
- SketchUp version: 2020
- License type: Pro
- Level of SketchUp: Beginner
by Calcifer » Fri Jul 02, 2021 3:03 am
Hello Fredo,
I am having an issue I never had before with animator: I animated some spinning gears. It works fine when I scroll through animator. But when I export, some gears don't spin. I go back to the project and they spin properly. Here are few odd things: some spin, some don't. The ones that don't, I tried to change the axis (from x to z) and it works. But when I move it again, it doesn't work anymore. I tried several things: changing the group/object axis. I also tried to rotate the gear within the group. It doesn't work. I tried to use the model axis and the object axis, same results. I also exploded the gears, regrouped them, gave them a different name and re animated: still doesn't work. The odd thing is when I create another object (cube, cylinder, I even tried another complex shape), it works. I have been using Animator for years now and it's the first time I get this specific issue. Thank you in advance
Calcifer
- Name: Calcifer
- License type: Pro
- SketchUp use: film and stage
by fredo6 » Fri Jul 02, 2021 6:31 am
Calcifer wrote:Hello Fredo,
If you could send me the model, I could have a look. Note that spinning symmetrical objects (like gears), may also give the impression of static movement when it spins too fast or at a multiple of the frame rate. I would suggest you put a color mark on the gears to verify whether they spin or not.
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by Calcifer » Fri Jul 02, 2021 2:59 pm
fredo6 wrote:If you could send me the model, I could have a look.
Hello Fredo and thanks for your response. It turns out indeed those specific gears are moving. I did slow them down and put a color mark. It works. Thanks again. I take the opportunity to ask a more genereal question about Animator: when a model is more complex, animator takes a while to respond (it can take up to 30 seconds to have a menu open - like, when I create a new movement). Granted I now have a lot of objects and moving parts in the file. In the past tried to lighten the model buy using proxies (for the static parts) but it remains the same. Outside of animator I can navigate very smoothly. I know my hardware is getting a bit old: which part of the hardware should be updated to increase animator performances? I think i have a decent cpu but my gpu is now very old. Thanks again for your fantastic plugin.
Calcifer
- Name: Calcifer
- License type: Pro
by fredo6 » Fri Jul 02, 2021 11:35 pm
Animator is dependent on the complexity of the model for some functions of the editor, as it needs to go through object hierarchy in the model.
Which 'menu' can take 30 seconds to open?
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by Calcifer » Sat Jul 03, 2021 6:54 pm
The best example is when adding a new movement. Clicking on the icon is instant but accessing the panel (translation, spin, rotate etc...) takes about 30 seconds. Then, it's fine, I can select the object almost instantly. Entering the value takes about 10 seconds to process the information. Then closing the new movement takes a bit of time as well. Also, If I want to edit a clip, it takes about 15 seconds to open it to adjust. My model is quite complex - I believe - so any change can take some time. Hence i was wondering if I could boost my computer in some way.
You got me curious about the hierarchy: does it mean that it would take more time to animate an object that is deep into the hierarchy over one that is at the top? I have to say I didn't notice any performance difference depending on which object I work on.
Calcifer
- Name: Calcifer
- License type: Pro
by Sugareth » Wed Sep 15, 2021 5:54 pm
Hi Fredo, Firstly, thanks for the animator plugin, I have used it many times over the years. I might have missed something obvious, but with the latest update I don't seem to be able to insert a rotation animation? Previous versions of the plugin this was fine. What am I doing wrong? Thanks Sugareth
Edit Second issue I am having, previously I could double click on a sequence and it would let me edit the translation etc. - has this functionality been removed?  Edit 2
Restarted Sketchup, the menu is now appearing OK. Edit 3... Trying to recreate the bug - appears to happen when I temporarily exit to Sketchup. The movement type window then doesn't reappear. When I close Sketchup I also notice that the "Temporarily Exit to Sketchup" dialog from Animator is still open.
Sugareth
- Name: Sugareth
by fredo6 » Fri Sep 17, 2021 4:45 pm
Could you open the Ruby console to see if there are error messages.
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by fredo6 » Tue Sep 21, 2021 6:55 am
New Release: Animator - v3.6a - 21 Sep 21Requirement: LibFredo6 v11.5Maintenance release_______________________________________________________________________________________ See plugin home page of Animator for Download of RBZ from the PluginStore. See Main Post of the Animator thread for more information.
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by nate101090 » Fri Dec 03, 2021 11:32 pm
HELP! I just installed and started using animator plug in today, and I created a long animation with many moving parts. I successfully saved an animator file along with my progress today, but not there seems to be a glitch. I can see all of the assets in the timeline, but I can't scrub through the timeline. When I click back to beginning it won't take me there, and when I click on generate video...all the windows disappear and I can't see the generate window box that I did see before. Not sure how to solve this glitch and open the generate window box again.
nate101090
- Name: nathan
- SketchUp version: 2018
- License type: Pro
- SketchUp use: hobby
by fredo6 » Sat Dec 04, 2021 8:49 am
Difficult to say anything without having the model.
At least, could you open the Ruby Console while running Animator.
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
by duanekemp » Fri Jan 21, 2022 3:21 pm
Hello, Trying to test Thea with Animator again with an older version of SketchUp (2020). When I launched Animator, it said that the version no longer worked and needed updating. I update LibFredo6 and through the SketchUcation store plugin, tried to update Animator. Didn't work. Tried direct download and SketchUp Extension Manager wouldn't work either, saying Failed to install Animator_v3.6.rbz and with the Extension store the message is UnZip Error: Could not upzip archive. Has something changed that it won't install on SU2020? Actually Version of Animator error Capture.JPG , just did the same exact thing in SU2021...
duanekemp
- Name: Duane Kemp
- License type: Pro
by duanekemp » Mon Jan 24, 2022 12:35 pm
And... for some reason, with SU2021, there was no problem with the update today! Hmmm. Interesting. I did nothing different.
duanekemp
- Name: Duane Kemp
- License type: Pro
by demiremre » Thu Mar 31, 2022 3:30 am
Hello Fredo I've been using Animator for a long time and I love it. Im working on a important animation work (deadline is tomorrow  ) but suddenly I got an error window like in the picture. I downloaded it and try to update but nothing has changed. It's seems on the latest version in extension manager. I deleted and reinstalled, used in higher sketchup versions but I got still same error. Windows 10 Sketchup 2020
demiremre
- Name: Emre D
- SketchUp version: 2015
- License type: Pro
by Calcifer » Thu Mar 31, 2022 4:41 am
Hello Fredo, Just wanted to mention that I have the same issue. I am also getting the message I have to update the plugin.
Windows 10, SU 2021
Thanks!
Calcifer
- Name: Calcifer
- License type: Pro
by duanekemp » Thu Mar 31, 2022 5:37 am
I too downloaded the 3.6 version for SU2022, didn't work. So I installed it with the SketchUcation store plugin... still didn't work.
Continue to get message:
"This version of Animator has expired Please upgrade to the lattest version
Go to the Download Page on Sketchucation?"
So, thought to try and update LibFredo6 to see if that was the culprit.
No change. Any suggestions?
And I confirm, SU2021 has the same issue.
duanekemp
- Name: Duane Kemp
- License type: Pro
by lhlhyi » Thu Mar 31, 2022 7:20 am
Animator V3.6a is expired today. I'm working on one urgent program. Where and when could we get the new version of the plugin?
Please reply as soon as possible!
lhlhyi
- Name: lhlhyi
- License type: Free/Make
by Saumil12345 » Thu Mar 31, 2022 8:34 am
I am also working on a tight deadline and the animator has expired, how can I get in working again?, Please reply as soon as possible. It is really urgent.
Saumil12345
- Name: Saumil Upadhyay
- License type: Pro
by Saumil12345 » Thu Mar 31, 2022 8:42 am
Hi Fredo,
Is there any hope that you release a new version or a fix to this issue today? I have to take a workshop on animator, but if the plugin is not working, I can't do anything, please reply as soon as possible, so that I can know if I will have to postpone the workshop or we are getting new version soon?
Thank you
Saumil12345
- License type: Pro
by fredo6 » Thu Mar 31, 2022 9:05 am
New Release: Animator - v3.7a - 31 Mar 22 21Requirement: LibFredo6 v12.8Maintenance release- Bug fixing
fredo6
- Premium Member
- Name: Fredo6
- License type: Pro
- Robot
Return to Animator Beta
