[Plugin Beta] Animator - v2.4b - 12 Mar 19 (SU2016+)
General discussion about Animator for SketchUp
Re: [Plugin Beta] Animator - v2.3c - 18 Nov 18 (SU2016+)
Postby rong1937 » Sat Dec 08, 2018 9:52 pm
Hope to support Enscape render
rong1937
Postby chals375 » Mon Dec 17, 2018 3:20 am
Hello.
First of all, I hope you understand the awkwardness of English.
Writing on the translator.
I used the animator 2.1a version and thea render v2.
I was using it well, but after updating the animator to 2.3c, I can't turn it on.
When I press the render button, the word "no clip defined in model" appears.
So do files with dozens of clips.
Everything went dead.
I want to use version 2.1a again, but it is not possible because the period of use has expired.
If I set my computer time to the past, I can use it, but because thea render license is not available, rendering is not possible.
How shall I do it?
Please help me.T.T
chals375
Postby fredo6 » Mon Dec 17, 2018 11:40 am
@chals375
1) First of all, can you play the animation interactively within Animator
2) Can you generate the video in natural mode (No rendering by Thea)?
3) Can you open the Ruby console while you are in Animator, to see i there are errors showing.
Finally, the best would be that you post or PM me your model so that I can have a closer look.
PS: do not play with the clock of your PC, as you can have many other bad side effects on other applications.
User avatar
PluginStore Author
PluginStore Author
Postby Tranthanhvu » Wed Jan 02, 2019 4:00 am
Tranthanhvu
Postby fredo6 » Wed Jan 02, 2019 7:04 pm
Tranthanhvu wrote:Can you help me.
https://youtu.be/eLUiA4i01Yo
For the rotation, you need to select the two arms objects, instead of the components which includes both arms.
User avatar
PluginStore Author
PluginStore Author
Postby Comial » Wed Jan 09, 2019 10:22 pm
fredo6 wrote:@chals375
I'm having the same issue since upgrading to v2.3. In response to your questions to @chals375
1) Yes, I can play the animation without any problems in Animator
2) Yes, I can generate the video in natural mode. Also, Thea render's animation tab can render Sketchup default animations but does not open a dialog when selecting Animator as the plugin.
3) Ruby console does not display any errors when trying to render from Thea Render
Rendering with Thea works just fine if I initiate it from Animator, but the only reason I want to render from Thea is so that I have control over what format the exported image sequence is in. If there is a way to do that from Animator then that would also solve my problem.
PS. I love all your plugins. Thank you for all your contributions to the Sketchup community!!
Comial
Postby fredo6 » Thu Jan 10, 2019 9:41 am
Comial wrote:Rendering with Thea works just fine if I initiate it from Animator, but the only reason I want to render from Thea is so that I have control over what format the exported image sequence is in. If there is a way to do that from Animator then that would also solve my problem.
I fixed the issue with the generation from Thea render in Animator 2.4a.
Please advise if this is ok for your now.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Beta] Animator - v2.4a - 10 Jan 19 (SU2016+)
Postby fredo6 » Thu Jan 10, 2019 9:42 am
New Release: Animator - v2.4a - 10 Jan 19
Requirement: LibFredo6 v8.7e
Minor release
  • Extension of validity
  • Fix a problem preventing to generate the video from Thea render
_______________________________________________________________________________________
See plugin home page of Animator for Download of RBZ from the PluginStore.
See Main Post of the Animator thread for more information.
User avatar
PluginStore Author
PluginStore Author
Postby Comial » Sat Jan 12, 2019 2:57 am
fredo6 wrote:I fixed the issue with the generation from Thea render in Animator 2.4a.
It does! Thank you, this is really great. I appreciate you providing such great support for your plugins.
Comial
Postby Oxer » Sat Jan 12, 2019 2:38 pm
It works fine on Mac too. :thumb:
User avatar
Oxer
Re: [Plugin Beta] Animator - v2.4b - 12 Mar 19 (SU2016+)
Postby fredo6 » Tue Mar 12, 2019 10:19 pm
New Release: Animator - v2.4b - 12 Mar 19
Minor release
  • Some bug fixes
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Animator Beta
Who is online
Visit our sponsors:
