Share your SketchUp models, materials and styles
by Gus R » Wed Apr 13, 2022 9:48 pm
I didn't know where to post this but I'm looking from someone to create a more accurate stone veneer texture for a rendering I'm working on for home owner's association. Is there a website or someone on here that would be able to assist me in this matter?
Gus R
- Name: Gus Robatto
- Operating system: Windows
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Rich O Brien » Wed Apr 13, 2022 10:17 pm
It's a texture you looking for? Have you any reference?
Rich O Brien
- Administrator
- SketchUp version: 2022
- License type: Pro
- SketchUp use: engineering and mechanical design
by Gus R » Wed Apr 13, 2022 10:25 pm
Sure do.
Gus R
- Name: Gus Robatto
- License type: Pro
by Rich O Brien » Wed Apr 13, 2022 10:57 pm
Did you search Castle on textures.com
Rich O Brien
- Administrator
- License type: Pro
by Gus R » Wed Apr 13, 2022 11:12 pm
I didn't but I'll look later. Might be too rustic. I've been using a material from poliigon.com which I thought was close enough but apparently there's someone at the homeowner's association with nothing better to do.
Gus R
- Name: Gus Robatto
- License type: Pro
by Rich O Brien » Wed Apr 13, 2022 11:34 pm
I have a Substance Designer file that is close[ish]....
Rich O Brien
- Administrator
- License type: Pro
by Gus R » Wed Apr 13, 2022 11:46 pm
Thanks Rich. They want an exact match which is rather unusual especially for something like stone. The material I use now is Brick Old 04 from Poligon. Some clients seem to think you can create assets at the press of a button. Screenshot 2022-04-13 at 16-43-17 Search - Poliigon.png
Gus R
- Name: Gus Robatto
- License type: Pro
by Rich O Brien » Thu Apr 14, 2022 12:00 am
Over here that's called Dressed Fieldstone and it's common enough. That might help with your searching.
I'll keep browsing what I have....
Rich O Brien
- Administrator
- License type: Pro
by pbacot » Thu Apr 14, 2022 12:10 am
Is something like this helpful. It looks a lot like Napa wall stone that we use around here but usually there's no lichen.
- Top SketchUcator
- Name: pbacot
- Operating system: Mac
- SketchUp version: 2019
- License type: Pro
by juju » Thu Apr 14, 2022 6:53 am
Gus R wrote:I didn't but I'll look later. Might be too rustic. I've been using a material from poliigon.com which I thought was close enough but apparently there's someone at the homeowner's association with nothing better to do.
Quote them for the asset creation, make it worth it as it won't be simple. See how serious they are about needing an exact match.
juju
- Premium Member
- Name: Juju
- License type: Pro
by Rich O Brien » Thu Apr 14, 2022 9:48 am
Kinda close...
Have you a wider photo with more stone in view?
Rich O Brien
- Administrator
- License type: Pro
by gullfo » Thu Apr 14, 2022 2:22 pm
Gus R wrote:... apparently there's someone at the homeowner's association with nothing better to do.
as i just moved into a neighborhood with an HOA - they want: the plat map, landscape plan, house elevations, topology map, and the actual stone samples (sent or brought to ARC meeting). so i can replace 50ft of crappy plastic edging with actual block... i'd hate to see what they want if i have to add a shrubbery! this is a site i've been using lately: https://www.sketchuptextureclub.com/
gullfo
- Premium Member
- Name: Glenn Stanton
- License type: Pro
by L i am » Thu Apr 14, 2022 2:31 pm
gullfo wrote:Gus R wrote:... apparently there's someone at the homeowner's association with nothing better to do.
For Council any "reasonable representation" of materials should suffice. Any of the suggested materials will work. Unless it is a heritage issue, In which case you would render with a "reasonable facsimile" Put the image you posted on the document, with the note "this is a detail of the stone finish represented on the 3D render"
- Premium Member
- Name: Liam day
- License type: Pro
- SketchUp use: landscape architecture
by Gus R » Fri Apr 15, 2022 3:11 am
Thanks everyone! We've sidelined this texture for the project for the time being.
Gus R
- Name: Gus Robatto
- License type: Pro
by gullfo » Fri Apr 15, 2022 3:43 pm
L i am wrote:For Council any "reasonable representation" of materials should suffice.
agreed, but that assumes rational people in the council... not always a given, and incumbency has its advantages when it comes to making a change of people composing the ruling group...
gullfo
- Premium Member
- License type: Pro
by Arengu » Tue May 24, 2022 12:28 pm
If you had a bigger picture of more stones I could make it seamless for you (make it a repeatable texture)... Here's a seamless version of the picture you sent earlier, perhaps that would work for you? With a bigger picture it would be better quality.
Arengu
- Name: Armand
- License type: Free/Make
- SketchUp use: education
by Gus R » Tue May 24, 2022 6:23 pm
Thanks Arengu. I requested the client to get a large image of the stone veneer to no resolve. I ended up getting a texture from someone else that resolved the issue.
Thanks to everyone else that chimed in.
Gus R
- Name: Gus Robatto
- License type: Pro
- Robot
Return to SketchUp Components, Materials & Styles
