image file location
Share your SketchUp models, materials and styles
image file location
Postby blueman2 » Sat Sep 20, 2014 1:56 am
Using Sketchup 8 in a PC There is an image file in a TV screen component that I want to change in a Sketchup project. I found the name of the image (samsung.jpg) using the material editor. I did a search and cannot find this image anywhere. Can someone please tell me where to locate it
blueman2
Re: image file location
Postby quantj » Sat Sep 20, 2014 4:09 am
I don't know where you can find the file of the custom texture. But if you need it the image, you can export your model as a 3d model, choose OBJ file type and in option choose to include texture maps. And then the export will give you a folder with all the textures in your file.
quantj
Postby Jim » Sat Sep 20, 2014 9:31 am
Textures are embedded in the model but you have a couple options.
If you select an image editing app under Preferences > Applications, then you can right-click the material in the Material Browser and open it in your selected app right from SketchUp.
You could also right-click the material in the Material browser and select "Export Texture Image", and then edit it in an external app, then apply the editor material.
Jim
Global Moderator
Return to SketchUp Components, Materials & Styles
