[solved] Material causes Bugsplat
Share your SketchUp models, materials and styles
Postby Burkhard » Wed Feb 08, 2012 4:18 pm
I'm on Win7 64 bit with the latest Sketchup build.
The attached file is from Jason Marantos RAL Librairie for Maxwell.
When applying it causes a bugsplat and Sketchup imidiately quit.
Can someone try if this happens on other Systems too?
Burkhard
Premium Member
Premium Member
Re: Material causes Bugsplat
Postby Gaieus » Wed Feb 08, 2012 4:51 pm
Hi Burkhard,
There is no problem on my 32 bit XP
Postby Burkhard » Wed Feb 08, 2012 4:56 pm
Thanks Gai, any other?
Burkhard
Premium Member
Premium Member
Postby TIG » Wed Feb 08, 2012 4:59 pm
That SKM material works fine for me [Vista 32bit SUp8M2 Pro].
I have another RAL set with a very comparable 'beige' SKM - although the RGB are off by one or two.
Your SKM has a slightly larger xml file when edited...
Code: Select all
    <n0:AttributeDictionaries count="1">
      <n0:AttributeDictionary count="1" name="maxwell">
        <n0:Attribute key="material" type="10">{"material":{"name":"Velvet_1001_Beige","alpha":1.0,"mxm":{"name":"Velvet_1001_Beige","thumb":{"dir":"C:/Documents and Settings/recording/My Documents/Maxwell/SketchUp/temp/thumbs","mtime":1282327667.0,"valid":true,"file":"Velvet_1001_Beige_1279301578.jpg"},"color":"134,124,113","file":{"dir":"C:/Program Files/Next Limit/Maxwell 2/materials database/mxm files/RAL Libraries/Velvet","mtime":1279301578.0,"valid":true,"file":"Velvet_1001_Beige.mxm"}},"textures":{"color":{"app":{"dir":"","mtime":0,"valid":false,"file":""}}},"color_mode":"app","mode":"mxm","version":"2.1.1.0","use_alpha":false,"color":"208,176,128,255","editable":true}}</n0:Attribute>
      </n0:AttributeDictionary>
    </n0:AttributeDictionaries>
It seems that the material has a Maxwell attribute added to it.
This does not affect me [I don't have Maxwell] but that might be what's causing you the issue.
Here is a modified version, without the attribute... Try that...
Global Moderator
Postby Burkhard » Wed Feb 08, 2012 5:11 pm
Thanks TIG, that works. Can you shortly explain what these attributes effect for Maxwell?
The Materials should be linked to the mxm file RAL Librarie.
Burkhard
Premium Member
Premium Member
Postby TIG » Wed Feb 08, 2012 5:31 pm
When you have certain renderers loading [I already know Twilight does this, and now I know Maxwell does too - and probably some other apps too], the renderer often has the ability to edit the properties of the SKP's materials as they might be used in the renderer; all of this while you are still inside the SKP. So for example a SKP material only has R/G/B/Alpha-transparency/Texture-file-data, BUT you might want additional settings for glossiness/reflectivity/etc in the renderer itself. So the renderer's material-editing tool adds these as "hidden attributes" attached to that SKP's material. When you export the material to the renderer, the extra info inside its "attributes" is also exported, so the renderer knows how reflective that material is etc... These attributes are stored with the material in the saved SKP; any material attributes are also replicated inside a SKM file when a material is exported outside of the SKP [as a SKM file], this is so when you reuse the SKM it already has suitable information for the renderer again...
Maybe there's a crossed thread in that SKM's "Maxwell" attributes causing the crash ?
As I said it loads OK for me using either your original or my manually edited SKM version...
Editing the contents of a SKM is a bit 'arcane'... BUT it's not so difficult after you realize that a SKM file is actually just a re-suffixed ZIP file containing the thumbnail image, perhaps a texture image and several cross-referenced XML files that contain the material's data [which are readable and editable in Notepad++.exe]... AND it helps a lot if you've previously created the SKMtool kit etc :roll:
Global Moderator
Re: [solved] Material causes Bugsplat
Postby Burkhard » Thu Feb 09, 2012 7:51 pm
A conflict between Maxwell attributes and SuPodium,Sketchup Bim and Driving Dimensions.All three forces Sketchup to splat. Thanks to all
Burkhard
Premium Member
Premium Member
Postby derei » Thu Feb 09, 2012 8:15 pm
Burkhard wrote:A conflict between Maxwell attributes and SuPodium. Thanks all
hmm, this should be reported... it needs a fix.
DESIGNER AND ARTIST DEREI.UK
derei
Postby Burkhard » Thu Feb 09, 2012 8:29 pm
Yes, I reported these on SuPodium and will do it here and with Ledas too.
Burkhard
Premium Member
Premium Member
Postby bigstick » Thu Feb 09, 2012 10:45 pm
I'll check out Podium and SketchUpBIM, but Maxwell I'm going to leave to NextLimit.
bigstick
Postby bigstick » Thu Feb 09, 2012 11:10 pm
Podium doesn't do anything with SKM files, I can't see how this has anything to do with us. I can't find a conflict with SketchUp BIM.
bigstick
Postby TIG » Fri Feb 10, 2012 12:38 am
Driving Dimensons does mess with some base-class/methods ill-advisedly [groups/definitions etc] - a while a go I PM'd the author about addressing it, but no news. Perhaps it also messes with some other classes I am unaware of...
Sketchup Bim is new and hopefully the authors are less cavalier ? Why do you not PM them too...
I'd not expect the other two quoted to be an issue.
Perhaps the latest Maxwell is faulty ?
Global Moderator
Postby d_e_x » Fri Feb 10, 2012 7:27 am
1. Can someone tell me what is Maxwell?
2. And where are these skm files coming from?
3. Who uses these files?
4. How do I download the package, and/or get more information on this library?
I googled "Jason Marantos RAL Librairie for Maxwell" and came up with a French website. Could someone help me understand this in English?
There is something fishy about these skm files. SketchUpBIM 1.5 does not touch / make any modifications or changes to any material data already inside SketchUp. So it beats me why and how are these skm files conflicting with the SketchUpBIM product. Also, I noticed that this bug is prevalent with the initial version of SketchUpBIM - which is just mind-boggling, as the first version of SketchUpBIM had absolutely no relation to SketchUp materials.
Dex
d_e_x
Postby bigstick » Fri Feb 10, 2012 9:17 am
Maxwell is a render engine. The RAL library is most likely a SketchUp materials library with advanced material properties for Maxwell configured in the xml file.
Personally I'm not sure you need to do anything. I seriously doubt there is a conflict with your application and the skm files. There seems to be no conflict with the SUPodium renderer.
You might want to check for conflicts with the driving dimensions plugin (a tool for parametric geometry) but in the unlikely event that there is a conflict between SketchUpBIM and the skm library, you could probably ignore it, it's not a Ruby plugin, and it may be that the way the additional properties have been added to the special skm files is broken in some way or other.
bigstick
Postby TIG » Fri Feb 10, 2012 10:28 am
To recap.
I discovered that the 'problem RAL SKM' file that was initially posted in this thread [by Burkhard] has several extra 'Maxwell' attributes added to the material compared to similar SKM files.
It might be that the original author had Maxwell installed when exporting the SKM files so they inherited these extra hidden attributes [unnecessary unless you are a Maxwell user].
I found that I could load and use the attributed SKM without any issues at all [I don't have Maxwell OR any of the now 'earmarked' tools loading - see below...].
I then manually edited the SKM file's code to remove the attributes and re-posted it, and it then worked without error with the original poster's set up as well as my own.
It now seems that the original poster [Burkhard] is having issues with other sibling materials causing crashes.
After some detective work Burkhard has deduced a shortlist of possible 'culprits':
SuPodium, SketchupBim and DrivingDimensions
He hasn't confirmed if he has Maxwell installed.
He needs to test with all combinations of these tools enabled/disabled, manually applying these 'attributed' materials also, to see if this causes issues...
Out of the three DrivingDimensions is a potential candidate because it does ill-advisedly mess with some base-classes/methods that can cause issues with standard API calls - although why it might interfere with materials is puzzling... Because it's compiled it's impossible to tell. I'd expect SketchupBim to use the basic xxx.material=mmm API coding so how this would conflict is also a mystery; does it do anything 'exotic' to materials otherwise ?
Perhaps DD is messing with SBIM [perhaps in a group/copy context?] when one of these materials is used and producing an error that in fact has nothing to do with the material itself ??
Has anyone else tried installing the original problem SKM file on a PC which also has any/all of these potential clashing tools? If so did it crash? As I said, it works fine for me with its Maxwell attributes but I have none of the listed suspects...
Burkhard: can you confirm what else you have installed - like Maxwell ? - and the exact steps you take to get to the crash...
Global Moderator
Postby TIG » Fri Feb 10, 2012 11:15 am
To add a little more confusion...
This is a typical SKM attribute set that Twilight adds
Code: Select all
xmlns:n0="http://sketchup.google.com/schemas/1.0/types">
    <n0:AttributeDictionaries count="3">
      <n0:AttributeDictionary count="1" name="Twilight">
        <n0:Attribute key="mat_changed" type="7">1</n0:Attribute>
      <n0:AttributeDictionary count="2" name="KT_Mat_c0">
        <n0:Attribute key="alpha" type="6">0.6000000238419</n0:Attribute>
        <n0:Attribute key="datatype" type="4">2</n0:Attribute>
      <n0:AttributeDictionary count="5" name="KT_mat">
        <n0:Attribute key="custom" type="4">1</n0:Attribute>
        <n0:Attribute key="ior" type="6">1.100000023842</n0:Attribute>
        <n0:Attribute key="shine" type="6">168</n0:Attribute>
        <n0:Attribute key="smooth" type="6">15</n0:Attribute>
        <n0:Attribute key="wireframe_thickness" type="6">0.003000000026077</n0:Attribute>
You will see that it adds three dictionaries and several separate attributes set of different 'types' [float/boolean/string/etc]
This is the attribute set in the SKM with Maxwell
Code: Select all
Maxwell saves all of its attributes in one dictionary name 'maxwell' using the key 'material' as a string [type=10] wrapped inside {} which I assume it uses to 'eval' back into something like a hash [you can't save a hash directly as an attribute] and extracts the various attributes needed.
I fail to see how any material having a long string attribute will cause other scripts to interact...
I think this is a Maxwell issue, as I now understand that Burkhard also has Maxwell loaded when the problem appears with the other tools...
Global Moderator
Postby Burkhard » Fri Feb 10, 2012 11:47 am
Sorry for beeing late. For sure, I have Maxwell installed and the Bugsplat occurs when after selecting the RAL Material I just apply it onto a face.
I had made some cross tests with these Plugins, so I'm sure that every single Plugin force Sketchup to quitt.
It is for those who could have the same problems - and me, because it is interesting to know what does skm Materials have to do with non Material Plugins.
It was mentioned in the BIM Plugin here, on SuPodium and Maxwell Forum too. For now Jason postet a part of a new RAL file, which I have to test now.
I'll keep you informed if they work.
Burkhard
Premium Member
Premium Member
Postby jason_maranto » Fri Feb 10, 2012 11:59 am
Just to be clear here this should definitely not be something that is specificity to my materials -- I didn't do anything special here... if you follow the process below you should get the same results I did:
1) open or create a new SketchUp material
2) link an MXM to that SketchUp material using the Maxwell plugin
3) save the modified SketchUp material to a new library
If you are getting a crash with my materials then you should also get a crash with any other material made in the same way.
For the record I do not have any issues on my systems, but I do not run the other plugins listed... and last thing I heard the reported issue was specific to localized versions of SketchUp.
Best,
Jason.
jason_maranto
Postby Burkhard » Fri Feb 10, 2012 12:14 pm
It was localized, Jason...after I copy my Plugin folder into the English Version it happens here also.
And...it is not you but still happens with the RAL Librarie and that's interesting enough.
Burkhard
Premium Member
Premium Member
Postby d_e_x » Fri Apr 06, 2012 1:45 pm
SketchUpBIM, Ledas Driving Dimensions and SU Podium work together like a champ! No problems, or issues were found. The attached screen-shot shows all 3 plugins working on the same model inside SketchUp.
My guess (and hope) is that the Maxwell issue was limited to the "modified" file posted on this forum. The cleaned-up version provided by TIG works fine.
d_e_x
Postby TIG » Fri Apr 06, 2012 2:55 pm
DrivingDimensions is still a culprit that ill-advisedly affects some of the the base class/methods for group [probably copy and definition] and thereby breaks other legitimate scripts.
Could be by redefining or poorly made observers.
It's compiled so it's not readily fixable...
I have as the author to change it ages ago - but to no avail :roll:
Global Moderator
Postby newyawksue » Sun Jan 27, 2013 5:19 pm
Hi. I'm just reading this conversation now because I'm having a similar problem. A material in my materials pallet is causing a crash every time I click on it. HOW DO I REMOVE THE MATERIAL FROM THE PALLET IF I CAN'T SELECT IT?? I don't want to accidentally select it at a later time and crash in the middle of this big project I'm starting.
Sue
newyawksue
Postby TIG » Sun Jan 27, 2013 8:11 pm
You can try this.
Copy+Paste the lines of code in turn into the Ruby Console + <enter>
Recent versions of Sketchup only, >=v8Mi...
I've assumed that assume the troublesome Material is name 'XXX', edit n= to suit.
First let's set up some variables:
Code: Select all
n='XXX';m=Sketchup.active_model;ms=m.materials;ma=ms[n];puts ma;
If it returns a material [not NIL] we now remove the material from everything:
Code: Select all
m.entities.each{|e|e.material=nil if e.respond_to?(:material) && e.material==ma; e.back_material=nil if e.respond_to?(:back_material) && e.back_material==ma}; m.definitions.each{|d|d.entities.each{|e|next if d.image?; e.material=nil if e.respond_to?(:material) && e.material==ma; e.back_material=nil if e.respond_to?(:back_material) && e.back_material==ma}}
Now we remove the material:
Code: Select all
ms.remove(ma)
The material should now be gone ?
Global Moderator
Postby raff » Thu Oct 24, 2013 6:36 am
Ok I also had the same problem as the Burkhard, this time with Jasons sketchup materials for arroway which also has maxwell attributes.
I fixed the problem by disabling SUPodium. If i re-enable SUPodium without any other plugins crashes return. I am using 32 bit SU8.0168 on a 64 bit Windows 7 and SUPodium V2.
raff
Return to SketchUp Components, Materials & Styles
