Vertex Gizmo question  Topic is solved
General discussion on SUbD for SketchUp
Postby Zaacharms » Fri May 08, 2020 5:15 pm
Is there a way to rotate with vertex tools in a plane that's different the default?
I'd like to rotate in the plane of the part not the global system.
Secondly, can the gizmo be re-positioned to a specific node?
Thanks again,
Marc
Zaacharms
Premium Member
Premium Member
Re: Vertex Gizmo question  Topic is solved
Postby McGordon » Fri May 08, 2020 6:05 pm
Right-click->Gizmo->Align to Custom
Then either choose a point and 3 axes, or shift click on a face or vertex.
To set to a specific 'node' choose an endpoint.
McGordon
Premium Member
Premium Member
Postby Zaacharms » Fri May 08, 2020 8:16 pm
Thank you.
Lot of helpful stuff under the R-click button! Probably should have found that myself.
Marc
Zaacharms
Premium Member
Premium Member
Postby thomthom » Sat May 09, 2020 11:05 am
Zaacharms wrote:Thank you.
Marc
The next version should make the options easier to discover. :)
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SUbD
Who is online
