SubD examples and models
General discussion on SUbD for SketchUp
Re: SubD examples and models
Postby Box » Fri Apr 27, 2018 1:50 pm
Any hint I give will make it too easy, think it through, what somewhat minor plugin makes SUbD work better.
Postby cotty » Fri Apr 27, 2018 2:11 pm
Split Tools?
cotty
Top SketchUcator
Postby Box » Fri Apr 27, 2018 2:16 pm
Well now when you say that Cotty, split tools is technically 2 different plugins, two by Tig and one by Rich. So I'll have to say no.
Postby cotty » Fri Apr 27, 2018 2:22 pm
[Plugin] TIG.splitdonut
cotty
Top SketchUcator
Postby Box » Fri Apr 27, 2018 2:23 pm
So all the plugins are?
I have to be sure you know.
Postby cotty » Fri Apr 27, 2018 2:26 pm
QFT, VertexTools, JPP and TIG.splitdonut?
cotty
Top SketchUcator
Postby Box » Fri Apr 27, 2018 2:27 pm
Excellent, now can you show me how?
Postby Box » Fri Apr 27, 2018 2:33 pm
Only joking, I've hijacked the thread enough already.
Problem is I posted the same question on my FB page so I'll be giving it away here. I've got my eye on you facebook lurkers.
8
Postby HornOxx » Fri Apr 27, 2018 6:30 pm
:thumb: :thumb: I want to subscribe to your BOX Gif Channel !!!! :) :)
Box, when you pull out all these selected squares with joint-push-pull, how do you succeed. that they taper like pyramids during this process at the same time?
never trust a skinny cook
HornOxx
Postby Box » Fri Apr 27, 2018 6:45 pm
HornOxx wrote:
Box, they taper like pyramids during this process at the same time?
On the toolbar that appears when you use JPP you have an option for taper.
As to the other go to facebook.com/boxgifs and enjoy.
Postby cotty » Fri Apr 27, 2018 6:52 pm
And if you don't see these options, you have to search for the "more options..." button.
cotty
Top SketchUcator
Postby HornOxx » Fri Apr 27, 2018 7:03 pm
thank you guys :D and finally learned this vocabulary
HornOxx
Postby Box » Fri Apr 27, 2018 7:12 pm
Here's one I posted way back.
If you had been following my FB Page you would have it sorted by now. :)
3
Postby cotty » Fri Apr 27, 2018 7:23 pm
applied to a sphere...
cotty
Top SketchUcator
Postby HornOxx » Fri Apr 27, 2018 7:44 pm
wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example :)
HornOxx
Postby Box » Tue May 01, 2018 2:20 pm
What can I say, I like hooks.
3
Postby cotty » Tue May 01, 2018 4:21 pm
And the hooks are just hooked up? ;-)
cotty
Top SketchUcator
Postby Box » Tue May 01, 2018 4:30 pm
There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
Postby Box » Wed May 09, 2018 5:33 pm
Here's a couple of tables using an array of a single SUbD components.
I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
The second would be far more stable.
I think I will have to build them just to see how well they work in the real world.
Postby Rich O Brien » Wed May 09, 2018 7:03 pm
Reminds me of this guy from the Snorks cartoon...
Rich O Brien
Administrator
Postby Box » Thu May 10, 2018 5:34 am
You've spent too much time with the twins Rich.
Postby Box » Tue May 15, 2018 4:00 am
A bit of SUbD Bling.
from this
we get this.
4
Postby pbacot » Tue May 15, 2018 6:38 am
Wow! would like to see detail on the necklace before and after and the links detail!
Top SketchUcator
Postby Box » Tue May 15, 2018 7:14 am
I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
Postby Box » Tue May 15, 2018 10:14 am
Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
Why describe when you can do.
Like this,
then distribute with your choice of stringer.
Postby HornOxx » Tue May 15, 2018 11:09 am
:thumb: :D so cool again Box - how did you get the individual limbs so well strung up next to each other?
HornOxx
Postby Box » Tue May 15, 2018 12:13 pm
HornOxx wrote: how did you get the individual limbs so well strung up next to each other?
That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
Component Stringer by Chris Fulmer
Comp String by Sam D Mitch
Path Copy by Smustard
or in this case Copy Along Curve by Anton S.
I rendered another after laying the links down flat to the body.
6
Postby Box » Sun May 27, 2018 6:09 pm
SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
6
Postby thomthom » Mon May 28, 2018 12:21 pm
I could use one of those chairs right now... :)
3
PluginStore Author
PluginStore Author
Postby HornOxx » Mon May 28, 2018 6:18 pm
:D end of may and already 32°C - I´ll take such a chair also :) Really excellent Box!
HornOxx
PreviousNext
Return to SUbD
