SubD examples and models
General discussion on SUbD for SketchUp
Re: SubD examples and models
Postby alsomar » Fri Oct 18, 2019 7:33 am
Hello there!
Here's a vintage fan I modelled yesterday. Besides SUbD I used some other extensions like VertexTools and QuadFace Tools.
4
User avatar
alsomar
Premium Member
Premium Member
Postby HornOxx » Fri Oct 18, 2019 7:39 am
... Prima !! :thumb:
never trust a skinny cook
User avatar
HornOxx
Postby Box » Fri Oct 18, 2019 9:41 am
Excellent.
User avatar
Postby alsomar » Fri Oct 25, 2019 7:32 am
An old fashioned caravan.
5
User avatar
alsomar
Premium Member
Premium Member
Postby HornOxx » Fri Oct 25, 2019 8:51 am
:D :thumb: ... again a so nice model idea - especially with the box-shaped carriage, I wouldn't have guessed SubD first :)
User avatar
HornOxx
Postby Box » Wed Nov 06, 2019 11:57 pm
A little early morning SUbD insanity, took quite a while to subdivide. I wouldn't have done the whole thing if I had thought about it properly, just one segment and array. But this is all one piece with thickness and is a solid. Added the cutaway to see the inner structure.
6
User avatar
Postby pilou » Mon Nov 25, 2019 3:28 am
Speedy Galerie
User avatar
Top SketchUcator
Postby Box » Mon Dec 09, 2019 2:49 pm
Just a bit of fun. For the absolute simplicity of it.
User avatar
Postby HornOxx » Mon Dec 09, 2019 6:18 pm
... wunderbar - how does this inner glass shape look like (raw)? Somewhere I read of "extra thumbs up" - you know where it right now comes from...
User avatar
HornOxx
Postby Box » Tue Dec 10, 2019 2:41 am
Is this what you mean?
I didn't save the model so I reproduced it.
Note the outer layer I have thickened with JPP, not shown in the original image.
User avatar
Postby Box » Tue Dec 10, 2019 4:55 am
This one shows how if you SUbD before JPP you get the sharp edges in the original render rather than the soft ones in the second model.
User avatar
Postby HornOxx » Tue Dec 10, 2019 7:09 am
Thanks, now I got it :) - I first assumed to see 2 shapes above. To see your competent handling with geometry is impressive allways :thumb: - for exampe that you started with a section plane to generate this first shape ...
User avatar
HornOxx
Postby Box » Tue Dec 10, 2019 7:27 am
No, you are right, there are two shapes, the red and the blue. The blue one fits around the red one.
Here's the rest of it, hope that makes sense.
3
User avatar
Postby HornOxx » Tue Dec 10, 2019 8:08 am
Yes :D - and I really enjoy this kind of geometry exercises ...
User avatar
HornOxx
Postby Vizan » Fri Dec 13, 2019 6:59 pm
cotty wrote:Hopefully the beginning of a looong and helpful topic...
How did you render with a square grid without triangles? It doesn’t work out for me((
Vizan
Postby Callegari_hr » Sat Dec 14, 2019 8:14 am
In QuadFaceTools plugin there is Convert Triangulated Mesh to Quads, select two triangles of one quad and run that tool.
Callegari_hr
Postby cotty » Sat Dec 14, 2019 1:15 pm
You can use this tool with no visible hidden geometry for it.
3
User avatar
cotty
Top SketchUcator
Postby Vizan » Sun Dec 15, 2019 4:12 pm
cotty wrote:You can use this tool with no visible hidden geometry for it.
After the Subd plugin, my model looks like on a screenshot. But when rendering a polygon mesh in Vray, I see triangles. I noticed that if the dividing line of the square is hidden, then it is not visible on the visualization.
It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
Vizan
Postby Box » Mon Dec 16, 2019 2:14 pm
This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
Render the shape then export the edges as a transparent background .png and combine the two.
Hera's a very simple example.
User avatar
Postby Vizan » Mon Dec 16, 2019 2:59 pm
Box wrote:This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
Thanks! This is a good idea)))
Vizan
Postby thomthom » Mon Dec 16, 2019 8:03 pm
Vizan wrote:It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Wed Dec 18, 2019 10:43 am
6
Speedy Galerie
User avatar
Top SketchUcator
Postby bahri06 » Mon Jan 06, 2020 8:48 pm
My first post here... still WIP Honda CB 175
Thanks to Pilou for all your tutorial on you tube channel
9
bahri06
Postby cotty » Mon Jan 06, 2020 9:01 pm
great model and impressive first post...
5
User avatar
cotty
Top SketchUcator
Postby pilou » Mon Jan 06, 2020 11:16 pm
Cool motor bike! :fro:
(Ps these above videos are not my own videos, alas! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby HornOxx » Tue Jan 07, 2020 4:41 am
:thumb: perfect! and a nice model idea :D
User avatar
HornOxx
Postby Vizan » Thu Jan 09, 2020 10:16 am
Thank you for your attention to this!
I noticed that the FredoCorner plugin does this automatically.
Vizan
Postby thomthom » Sat Jan 11, 2020 2:35 pm
Wow - that's an impressible detailed model! Very nice topology as well! :thumb: :thumb:
3
User avatar
PluginStore Author
PluginStore Author
Postby panixia » Mon Jan 27, 2020 1:36 pm
Dirt jumping bike trails.
Sub-d concept
3d printed version :-P
4
User avatar
panixia
Postby panixia » Mon Jan 27, 2020 6:21 pm
thomthom wrote:I just need to make sure it doesn't have any other unintended side-effects.
Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. :|
IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
Vizan wrote:Thank you for your attention to this!
Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
I think that's a good approach, because it can be adapted for different workflows.
User avatar
panixia
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SUbD
Who is online
Visit our sponsors:
