Hi there,
can someone tell me how to use assets like the one I attached from quixel using skatter?
Is that possible with sketchup or those are for other programs like UE?
How to use something like this from Quixel with SkatterModerator: jiminy-billy-bob
• Page 1 of 1
Re: How to use something like this from Quixel with SkatterOf course you can : assets can be taken like any components!
![]() I suppose they are OBJ formats so you must import them with something like import OBJ by Tig if you have not the Pro version of SU
Re: How to use something like this from Quixel with SkatterI have Transmurt since the day come out and I love it but these type of items are just images no 3D objects. There are jpg for Albedo, Bump, Disp and opacity. I can put them on a surface and render them but they will be in the same order and shape of the image instead I need to mix them and skatter them
Re: How to use something like this from Quixel with SkatterThese are 3D assets, right? It's not a 2D atlas?
As 3D objects, you should be able to simply pick them one by one in Skatter's "Scattered Objects" rollout.
Re: How to use something like this from Quixel with SkatterCould you create a component, paint it with the texture image you have from Quixel and then use skatter with the created component?
Re: How to use something like this from Quixel with SkatterIt's already a 3D component : https://quixel.com/megascans/home?searc ... Id=rfkkwaa
No 3D objects only images as the attachment I posted.
Ooops....I don't know why the LOD wasn't check in the download. Anyway let's forget that one the problem is still there unless I'm missing something. How can I use the Atlases and skatter them?
Re: How to use something like this from Quixel with SkatterI'm 100% sure that this is a 3D asset, and you can import it in Transmutr. Take a look at this:
Oh sorry, I didn't see your post before I posted the gif. For atlases, I'm afraid you will have to cut them manually. Something like this: https://quixel.com/blog/2019/10/30/crea ... ng-atlases https://www.youtube.com/watch?v=whfDsjO6bmg
Re: How to use something like this from Quixel with SkatterThat is what I was doing...I really hope there was an easier way.
Thanks for the help ![]()
Re: How to use something like this from Quixel with SkatterI don't think so, unfortunately. Even Quixel tells us to do it this way.
• Page 1 of 1
Users browsing this forum: bubbavox and 1 guest
