[BUG] skatter increases memory footprint endlesslyModerator: jiminy-billy-bob
• Page 2 of 2 • 1, 2
Re: [BUG] skatter increases memory footprint endlesslyI'm getting this problem now, I was playing with a scene, added a bunch of trees, did a render plus channels, saved the project, closed SU2015.. did manly duties ie feed the tribe then loaded the scene and its 20mins later and still loading cpu is at 15% memory for SU is creeping up but still under 2gb of 8gb.. its showing 50% free
the scene itself is only 24meg and I just used boxes, Thea took around 15secs to build when I did the earlier render and wasn't stretched at all.. still busy “It’s only impossible if you stop and think about it!”
Re: [BUG] skatter increases memory footprint endlesslyWhen I get this issue, I kill SU manually, relaunch it , in prefs unable skatter, relaunch SU, open the file, and then re-enable skatter, regenerate the skatters.
Re: [BUG] skatter increases memory footprint endlesslyI have a bug in 1.0.3 that make Skatter 10 times slower in some cases, maybe that's what you're seeing.
A new build will be released in the next few days.
Re: [BUG] skatter increases memory footprint endlesslyThanks optimaforever, I just went back to the backup version without the Skatter, I wasn't really finished with the scene, I was just showing someone how to do a position channel pass and depth for post pro mist/fog.. but if I have it happen again I'll do as you say
![]() The tree's were Skatter content I made, I think the mod.thea is around 15meg, the simple skp is basically the same as sKatter ones from the library, the skp tree is a scary 120 meg but I didn't use that, I only made it trying different ways to get a XFrog tree into SU If I do it again I'll take a note of the amount of instances Thea has so you get some idea how much was in the scene, but I plan to place the trees better so its a bit more economical so I can do the grass with out killing the project “It’s only impossible if you stop and think about it!”
Re: [BUG] skatter increases memory footprint endlesslyI think i noticed the same behavior. After a few hours without activity with Skatter in preview mode i got this:
After a restart of sketchup the memory usage was set back to ~250 MB and then i started a new skatter preview and it began counting up again (~7,5 GB after 3 hours) Re: [BUG] skatter increases memory footprint endlessly
It's been almost 3-weeks ![]() i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: [BUG] skatter increases memory footprint endlesslyThere's a frontroom and a backroom....reverse faces
Re: [BUG] skatter increases memory footprint endlesslySo the RAM usage if going up slowly over several hours?
Re: [BUG] skatter increases memory footprint endlesslyYes. In increments of maybe 40-80 KB every second. It also happens when i only use "Edit skatter group" on an old skatter object. Nothing more to do, only open the scatter dialog.
Re: [BUG] skatter increases memory footprint endlesslyOk thanks, I'll investigate.
You are on Windows7? Sketchup 2016?
I know, but it doesn't fix the problem. Off Topic @Rich IMHO the new emoticon set is way worse than the old set. By the way, why is the emoticon with the dark glasses named "fro"? i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: [BUG] skatter increases memory footprint endlesslyWe messed up importing a new set.
We plan upgrading forums this year so no real point fixing them until the whole thing gets an overhaul. There's a frontroom and a backroom....reverse faces
You're the best. ![]() End of Off-Topic i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
