Is there a way to define the spacing in regard to the face normal instead of x and y? Or what would be the right way to get the same density at the vertical faces here?
[Q] spacingModerator: jiminy-billy-bob
• Page 1 of 1
Re: [Q] spacingFor now the projection is only on the vertical axis, but this will change in the future.
Re: [Q] spacing
you mean, to skatter a vertical garden, one need to create it on an horizontal plane, and then rotate it once the skattering as components has been done? or just keep a slight slope (89° for example) to have a small horizontal surface)?
Re: [Q] spacingBoth will work. But it'll be far better when I introduce any-axis-projection.
Re: [Q] spacingCannot wait to be able to do this, right now the only way is with the fur plugin which lacks much control.
• Page 1 of 1
