... my exclude street?
[Q] What's wrong with...
Moderator: jiminy-billy-bob
• Page 1 of 1
Re: [Q] What's wrong with...The problem is that all edges are not welded. You have two curves and to single edges.
Skatter tries to re-weld everything, but the algorithm is still not perfect and in that case it fails. If you weld all the edges in your road group, it'll work fine.
Re: [Q] What's wrong with...I've tried it and welded all street edges to one curve, but it doesn't make a difference?
Did you try clicking on the update button in the Areas rollout?
Re: [Q] What's wrong with...Of course not
![]() Now it works, thank you for your fast help.
Re: [Q] What's wrong with...No problem
![]() Thanks for your feedback, it reminds me that I really need to improve that re-weld algorithm...
Re: [Q] What's wrong with...Or a hint that something has changed and an update should be made.
Changed result...
• Page 1 of 1
