[RELEASE] Beta 0.3.0
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby jiminy-billy-bob » Tue Nov 24, 2015 2:12 pm
Beta 0.3.0
Very important : Skatter now installs to a different location, so you need to uninstall previous versions and make sure every file is deleted. Otherwise you'll get duplicate conflicting files...
On Windows :
  • Go to the Control Panel > Programs and Features and uninstall Skatter
  • Then delete these folders and files if they still exist :
    • C:\ProgramData\Skatter
    • C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\jbb_skatter
    • C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\jbb_skatter.rb
    (Same for all the Sketchup versions)
On OSX :
Delete these folders and files :
  • /Users/USERNAME/Library/Application Support/Skatter
  • /Users/USERNAME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_skatter
  • /Users/USERNAME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_skatter.rb
Once you've double-check that all Skatter files are deleted for every sketchup version, you can safely install the new version of Skatter.
Changelog:
  • Added translations*
  • Skatter is now installed in C:/ProgramData/... on Windows, and in /Library/Application Support/... on OSX.
  • Fixed an issue in SU2016 where the Skatter dialog losed focus when trying to type an input value
  • Fixed an issue when opening models containing no attribute dictionnaries.
*Skatter automatically detects the language of Sketchup and uses the same for its own dialog if a translation is found.
For now there's only a complete French translation. You can also find a .strings file in jbb_skatter\Resources\en-US with the original english strings. If you want to translate Skatter in your own language, copy this file and paste it in a new folder in jbb_skatter\Resources. The folder you create should be named as the localization tag of your language. Here are a few exemples :
en-US, fr, it, de, es, ja, ko, zh-CN, zh-TW, pt-BR, nl, ru
You can also force a language for Skatter in the Options tab.
If you translate it, let me know and I can add your translation to the official version :)
FYI : We will open a semi-public beta to 50 early-adopters very soon! :D
Download here : http://download.getskatter.com/
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [RELEASE] Beta 0.3.0
Postby driven » Tue Nov 24, 2015 2:43 pm
hi Thomas,
why are you moving to the HD/Library/ on mac's?
anything that can run from there should run from the ~/Library useless you hardcode it not to...
I personally dislike not having the choice of keeping everything within my User space or not...
john
driven
PluginStore Author
PluginStore Author
Postby jiminy-billy-bob » Tue Nov 24, 2015 2:47 pm
Because otherwise, admins can't install for regular users. And only admins can install it.
Or am I mistaking?
And the Skatter Library should be installed in HD/Library/ anyway, because of distributed rendering issues.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TedVitale_CG » Tue Nov 24, 2015 4:17 pm
This essentially breaks everything we've done.
Ted Vitale
3D Artist|Trainer
Chaos Group USA
http://www.chaosgroup.com
TedVitale_CG
Vray Support
Vray Support
Postby jiminy-billy-bob » Tue Nov 24, 2015 4:19 pm
TedVitale_CG wrote:This essentially breaks everything we've done.
Why? What breaks?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TedVitale_CG » Tue Nov 24, 2015 4:25 pm
Why? What breaks?
Not sure yet, still testing. Worked yesterday, updated to 0.3.0 and its not working.
Ted Vitale
3D Artist|Trainer
Chaos Group USA
TedVitale_CG
Vray Support
Vray Support
Postby jiminy-billy-bob » Tue Nov 24, 2015 4:26 pm
You mean with existing files?
Anything in the console?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TedVitale_CG » Tue Nov 24, 2015 4:35 pm
It looks like your not actually passing us a valid path to the proxies. can you fix this?
SKATTER_LIBRARY_PATHskatter_medium_grass_01_large.vrmesh
Thanks Thomas!
Ted Vitale
3D Artist|Trainer
Chaos Group USA
TedVitale_CG
Vray Support
Vray Support
Postby jiminy-billy-bob » Tue Nov 24, 2015 4:42 pm
Weird, this was already implemented in 0.2.2.
Are you on Windows or OSX?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TedVitale_CG » Tue Nov 24, 2015 4:44 pm
I'm on Windows, Noel is checking it on OSX. You may want to ping him or Joe for a more specific outline of the issue at hand.
Ted Vitale
3D Artist|Trainer
Chaos Group USA
TedVitale_CG
Vray Support
Vray Support
Postby jiminy-billy-bob » Tue Nov 24, 2015 4:46 pm
All three of you have the issue?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Tue Nov 24, 2015 6:23 pm
Installation went smooth. Didn't get the previous false positive either. :thumb:
When installing I got a Windows smart screen popup asking if I want to install app from a unknown publisher. (Windows 8.1)
I think this has to do with certification.
Maybe you could ask another developer like Thomasz how he does it?
Will try installing tomorrow at work...
Pixero
Postby solo » Tue Nov 24, 2015 6:50 pm
Has the serial changed? I cannot get 6sblp-7GdCN-Z1Y3X-E0O4a to work any more
http://www.solos-art.com
solo
Global Moderator
Postby Pixero » Tue Nov 24, 2015 6:54 pm
You should have received a personal serial in the mail.
Pixero
Postby solo » Tue Nov 24, 2015 6:59 pm
Pixero wrote:You should have received a personal serial in the mail.
I probably never participated enough.
solo
Global Moderator
Postby nektares » Tue Nov 24, 2015 7:18 pm
No problems here, smooth transition. win7, SU2015, Thea4Su
nektares
Postby solo » Tue Nov 24, 2015 8:00 pm
or I do not read and follow instructions, apparently i never submitted my email address, fixed now. :)
solo
Global Moderator
Postby JQL » Tue Nov 24, 2015 9:45 pm
At first notice the only thing I found that's not working is the following:
http://help.getskatter.com
That can't be open from plugin or from a standard browser.
JQL
Premium Member
Premium Member
Postby jiminy-billy-bob » Tue Nov 24, 2015 9:53 pm
Yeah sorry, redirection issue. It'll soon point to : http://skatter.helpscoutdocs.com/
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby JQL » Tue Nov 24, 2015 10:12 pm
jiminy-billy-bob wrote:Yeah sorry, redirection issue. It'll soon point to : http://skatter.helpscoutdocs.com/
No problem at all! I was just testing the buttons... Don't forget that on release.
JQL
Premium Member
Premium Member
Postby JQL » Tue Nov 24, 2015 10:17 pm
This made me try the new helper.
I don't like it very much. I prefered the old one though the reading was easier, though separating subjects was harder.
Basically I'd mix both. On the current version I'd use the left menu wich is nice but ditch the right one wich breaks reading flow.
As an example, clicking on a link of the right list, sends us to a help content that, sometimes is a one liner sentence.
I think skatter is simple enough to have the topics on the left and full text for each topic on the reading area on the right.
Do you think I explainned well enough? (I honestly don't think so...)
JQL
Premium Member
Premium Member
Postby jiminy-billy-bob » Wed Nov 25, 2015 10:24 am
Thanks again for your feedbakc Joao :) The help portal is very WIP, so feedback is very valuable!
jiminy-billy-bob
PluginStore Author
PluginStore Author
Return to Skatter
