Got an Art Director asking about using sketchup geometry to drive a 5-axis CNC machine. Have found apps advertised for preparing SU files for the purpose but the process looks torturous and so far as I know SU is not a favored tool for the modeling -> CNC pipeline.
Does anyone have recommendations for a process that works well for moving sketchup geometry over to the CNC side, and/or any typical constraints or difficulties encountered in doing that?
Thanks in advance.
K
File Output for 5-Axis CNC Machining?
• Page 1 of 1
Re: File Output for 5-Axis CNC Machining?Did you look at SketchUcam?
https://github.com/swarfer/sketchucam/releases Did you try Freecad to Gcode Export? Or are you dealing with SKP files primarily?
everything is starting as skp files Re: File Output for 5-Axis CNC Machining?Only one I knew is SketchUcam. Sorry, not much else to add.
SketchUp is a poly modeller so TRUE curves aren't possible. You will always fight against segments causing facetting. I believe SketchUcam's extport to g-code was quite adequate on flat sheet cuts. But 5-axis stuff could be a bit of a stretch.
• Page 1 of 1
