Creating 3D Printable Footpad
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby lmtsketch » Thu Feb 23, 2017 6:35 pm
I have been struggling to create a base that 2 legs will insert into and a place to hook a bungee cord. I am using Sketchup Pro 2017 Solid Tools and SolidInspector2 plugin. I want to insert the 2 smaller, angled cylinders into the round base cylinder. 2 legs will fit into the 2 cylinders. I also want to create a hook by subtracting the torus from the round base.
My attempts have been trimming the 2 small cylinders into the round base and then subtracting the torus. I always lose the solid object of the resultant object. I would appreciate any help.
lmtsketch
Premium Member
Premium Member
Re: Creating 3D Printable Footpad
Postby Rich O Brien » Thu Feb 23, 2017 6:42 pm
Scale the object 100x then do your subtracting.
Afterwards scale it back down 0.01
I would do it to your model but I wasn't entirely sure what was getting added and what was getting removed.
Rich O Brien
Administrator
Postby lmtsketch » Thu Feb 23, 2017 7:51 pm
Zooming did help with subtract. The end result should look like the attached image except I was hoping to have bottoms in the 2 inserted cylinders. After the operations I do not end up with a solid.
lmtsketch
Premium Member
Premium Member
Postby Rich O Brien » Thu Feb 23, 2017 8:54 pm
Those shape are not going to boolean.
The tube has no end/bottom
The Oval hangs over the edge.
You need to rework the inserts to fit.
Rich O Brien
Administrator
Postby lmtsketch » Thu Feb 23, 2017 10:33 pm
I'm not clear what you mean by the "shapes will not boolean". The sub shapes were all solids. (I put tops and bottoms on all of them. I then deleted the tops after trimming. Zooming and ensuring none of the small shapes were touching inside the base worked. The piece is way larger than I want, but it is a start. Thanks for the help.
lmtsketch
Premium Member
Premium Member
Postby d12dozr » Fri Feb 24, 2017 2:02 pm
Something like this?
You may download the attached SKP file and follow the scenes to see how I did it.
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby lmtsketch » Sat Feb 25, 2017 3:34 am
I can't recreate your steps. I think I am not doing Scene 3 correctly. Do you explode the pieces and just group the interiors?
lmtsketch
Premium Member
Premium Member
Postby lmtsketch » Sat Feb 25, 2017 1:46 pm
OK, after some sleep, I successfully repeated what you did. Even scarier,I understand what you did.
THANKS for the great help!
lmtsketch
Premium Member
Premium Member
Postby d12dozr » Sat Feb 25, 2017 1:52 pm
Excellent, glad it helped! :thumb:
d12dozr
Top SketchUcator
Return to SketchUp for 3D Printing
