Create lego-like solid pieces for assembly  Topic is solved
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby Guillo_Ortiz » Tue Jan 03, 2017 10:27 pm
Hi!
I'm attempting to make a split model for 3d printing and I'd like it to have joints to get a firm grip when assembled (like a lego).
This is what I have:
Does anyone know of a plugin or a way to get this done?
User avatar
Guillo_Ortiz
Re: Create lego-like solid pieces for assembly
Postby Rich O Brien » Tue Jan 03, 2017 11:20 pm
Do you have an idea of the joint type you'll use?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Re: Create lego-like solid pieces for assembly  Topic is solved
Postby sdmitch » Tue Jan 03, 2017 11:26 pm
Guillo_Ortiz wrote:Hi!
Here is a start. You will need to change the values to suit your situation.
Code: Select all
unless file_loaded?((__FILE__))
   UI.add_context_menu_handler do |menu|
      sel = Sketchup.active_model.selection
      if sel.first.is_a?(Sketchup::Face)
         menu.add_separator
         menu.add_item('Dimple') {
            face = sel.first; ctr = face.bounds.center; nrm = face.normal
            cir = Sketchup.active_model.active_entities.add_circle(ctr,nrm,0.125,12)
            pts = cir.map{|e|e.vertices}.flatten.uniq.map{|v|v.position}
            fac = Sketchup.active_model.active_entities.add_face(pts)
            fac.pushpull -0.25 if fac
         menu.add_item('Pimple') {
            fac.pushpull  0.25 if fac
   file_loaded((__FILE__))
http://sdmitch.blogspot.com/
User avatar
sdmitch
PluginStore Author
PluginStore Author
Postby Guillo_Ortiz » Tue Jan 03, 2017 11:31 pm
Rich O Brien wrote:Do you have an idea of the joint type you'll use?
Not really, any type will do.
User avatar
Guillo_Ortiz
Postby Guillo_Ortiz » Wed Jan 04, 2017 12:05 am
Code: Select all
         menu.add_separator
Thanks for the plugin! It's very close to the effect I'm looking for. BTW, how can I change the units to cm? I tried writing "cm" and " cm" after the number, but got an error.
User avatar
Guillo_Ortiz
Postby sdmitch » Wed Jan 04, 2017 1:54 am
The syntax is ".cm", so 1.inch = 2.54.cm
User avatar
sdmitch
PluginStore Author
PluginStore Author
Postby Guillo_Ortiz » Wed Jan 04, 2017 10:08 am
Thanks, sdmitch. In the end I used your method.
Thanks a lot!
User avatar
Guillo_Ortiz
Postby JQL » Wed Jan 04, 2017 10:15 am
That won't have a very firm grip as it will twist upon the joint's axis. You should have at least 2 pins per joint... It also seems very prone to detach from each other. Maybe you now should model from what Mitch gave you.
User avatar
JQL
Premium Member
Premium Member
Postby Guillo_Ortiz » Thu Jan 05, 2017 10:17 pm
JQL wrote:That won't have a very firm grip as it will twist upon the joint's axis. You should have at least 2 pins per joint... It also seems very prone to detach from each other. Maybe you now should model from what Mitch gave you.
Thanks, I will. I'm also going to use super glue to reinforce it.
User avatar
Guillo_Ortiz
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp for 3D Printing
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
