solid objects and wall thickness
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby CJFugate » Fri Nov 18, 2016 8:41 am
I've been pulling my hair out over this for days, so I appreciate any help.
I'm trying to make a very simple part. Just a solid cylinder with 9 hollow cylinders running through it. Everything looks fine, entity info says that it is a solid group with a volume, but when I try to have Shapeways print it I'm told they can't print it because the walls are too thin. In Sketchup none of the lines are closer than 1mm, so I don't understand what I'm doing wrong. Please help! Thank you for your time.
CJFugate
Re: solid objects and wall thickness
Postby kaas » Fri Nov 18, 2016 12:15 pm
The problem I see is: the solid object is nested into another group.
Open Window-Outliner and you can see the hierarchy. Explode the outside group so you only have the solid object.
I would also move the object to the origin. That never hurts.
Edit: and if that doesn't help - contact the support people from the 3d printing company because I don't see any problems with the 1mm either. Sorry for your hair...
kaas
Postby pilou » Fri Nov 18, 2016 1:02 pm
After a complete general Explode : this part was considered as Self-intersected
Solid Solver by Tig resolves that! :)
Speedy Galerie
Top SketchUcator
Postby CJFugate » Fri Nov 18, 2016 5:42 pm
I very much appreciate the help. I have the whole object grouped. Entity info says "Solid Group". If I select the whole group, right click, and select "explode" I now have 7807 entities.
So I'm sorry, but I'm not really sure what you're asking me to do.
CJFugate
Postby d12dozr » Sun Nov 20, 2016 2:44 pm
Hi Corey, check that the model is uploaded at the correct scale on Shapeways. I uploaded your model without any changes, and it shows up fine for me, so that's the only thing I can think of!
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Return to SketchUp for 3D Printing
