watercolor palette for shapeways
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby tallbridgeguy » Sat May 30, 2015 2:39 pm
Hi, I'm new to shapeways and 3d models. I wanted to see if I could upload a 3d model to shapeways and I can but I can't seem to make a simple tray with two recessed paint wells?
This is the model and I realize the floor doesn't have any thickness but I tried thickness and it just filled in the holes.
Is it best to export from sketchup to a stl file or use meshlab and then a stl file?
thanks for the help. (d12dozr I didn't want to keep bugging you)
Stuart
tallbridgeguy
Re: watercolor palette for shapeways
Postby cotty » Sat May 30, 2015 3:11 pm
You can use Fredos plugin JPP (joint push pull) to add thickness. STL is fine for 3D printing.
cotty
Top SketchUcator
Postby tallbridgeguy » Sat May 30, 2015 3:46 pm
Thanks, that worked great! Now I can design a whole box and print it.
s
tallbridgeguy
Postby tallbridgeguy » Sat May 30, 2015 8:38 pm
A few of more questions.
I made the two sides, one for mixing paint and one for holding paint.
1) any advice on a hinge for the box? I thought some hollow tubes and then I would put a metal rod through the holes when I get it.
2) could this whole piece be printed together somehow?
3) I made everything 1/16" thick. Will that be strong enough? The trays are each 7/16" tall
Thanks!
s
tallbridgeguy
Postby cotty » Sat May 30, 2015 8:43 pm
Which material will you use? There are design rules for every material and they are different...
cotty
Top SketchUcator
Postby tallbridgeguy » Sat May 30, 2015 8:46 pm
Strong and flexible plastic?
thanks!
s
tallbridgeguy
Postby cotty » Sat May 30, 2015 9:04 pm
Here are the design guidelines for this material...
http://www.shapeways.com/materials/stro ... guidelines
cotty
Top SketchUcator
Postby tallbridgeguy » Sat May 30, 2015 9:11 pm
Thanks for the info! I think 1/16" = 1.5875 mm so it should be doable. Whether it is strong enough I don't know? Most of my plastic palettes are 1/16" thick, so I think it should work.
I can print them separately but I need some hinges?
thanks!
s
tallbridgeguy
Postby cotty » Sat May 30, 2015 9:28 pm
you can try to add some hinges, one example...
cotty
Top SketchUcator
Postby tallbridgeguy » Sat May 30, 2015 10:04 pm
That's cool but I'm not sure how it works?
s
tallbridgeguy
Postby cotty » Sat May 30, 2015 10:33 pm
It's a kind of a simple click system...
cotty
Top SketchUcator
Postby tallbridgeguy » Sun May 31, 2015 12:59 am
That is really cool, have you tried on it on a project? I might have to go that a go.
Thanks again for all the help! :thumb:
s
tallbridgeguy
Postby cotty » Sun May 31, 2015 8:09 am
No, I haven't. The difficult part will be to choose the right fit so that it can be rotated slightly and still holds together.
cotty
Top SketchUcator
Postby d12dozr » Sun May 31, 2015 12:00 pm
Stuart, I'm always glad to help you, and even more pleased to you posted publicly. This way others with the same questions will benefit and you get answers faster. :)
I would try a sort of piano hinge, where half of the hinge parts are on the top of the box, and the other half are on the bottom half, then run a brass rod through for a pin.
(not my image)
1/16" should be thick enough, but you will have to paint or otherwise seal the plastic because it is very porous.
You should also increase the resolution of the circles used to make the paint holding trays so that you get a smoother surface. Running fredo's Roundcorner plugin on the sharp corners is a good idea.
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby tallbridgeguy » Sun May 31, 2015 1:22 pm
Thanks I will give that a go! :thumb:
s
tallbridgeguy
Postby tallbridgeguy » Sun May 31, 2015 5:52 pm
I have put some hinges on the boxes.
So the question, is it worth about $60 to print it?
How porous is the plastic, will it leak?
I just noticed I have to put some bump outs by the hinges, so when it is open it will stay flat..
thanks for all the help!
s
tallbridgeguy
Postby d12dozr » Mon Jun 01, 2015 6:16 am
The hinges you made look great! Yes, the plastic will leak unless you paint it. $60 sounds about right for commercial printing. You could get it printed cheaper on a small desktop FDM machine, but the quality won't be nearly as good and you'll still have to seal it with paint or epoxy.
d12dozr
Top SketchUcator
Postby tallbridgeguy » Sat Jun 06, 2015 2:05 pm
I bought the four well side of the palette, $23 bucks delivered. I chose white polished plastic...
I thought I would see how good it is before buying the other side.
Thanks for all the help!
Stuart
tallbridgeguy
Postby d12dozr » Mon Jun 08, 2015 2:56 pm
:thumb: good thinking to just print a small part for testing, Stuart. Please let us know how it goes!
d12dozr
Top SketchUcator
Postby tallbridgeguy » Wed Jun 24, 2015 2:53 am
I made a quick video to show the finished product.
s
tallbridgeguy
Postby d12dozr » Wed Jun 24, 2015 5:00 am
Looks great, Stuart!
d12dozr
Top SketchUcator
Postby tallbridgeguy » Sat Jun 27, 2015 1:26 pm
Thanks for all your help!
It went great and I'm looking forward to doing more 3D things!
s
tallbridgeguy
Return to SketchUp for 3D Printing
