Looks solid but isnt....
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby NCO » Wed Dec 03, 2014 9:45 pm
Hello all,
First post on here and its for a problem I cant seem to solve (total lack of experience trying to use anything to make 3D images.
I have used the solid inspector and it says I have a problem (which is interesting because before I combined the two objects they were individually solid).
I have tried to tidy up the offending area but any time I delete any lines it takes away the whole surface. Id really appreciate any advice....
NCO
Re: Looks solid but isnt....
Postby Box » Wed Dec 03, 2014 10:42 pm
There are double faces across the front.
Just remove them and it will be solid.
Also orient your reversed faces or it will never work in printing.
Purge your files before uploading them, it reduced it to 450kb.
Postby NCO » Wed Dec 03, 2014 11:01 pm
Thanks. I will give that a go.
Possibly a stupid question, how do you orient a face? Is this why some of them are grey in colour? (I was curious about that).
NCO
Postby NCO » Wed Dec 03, 2014 11:07 pm
NCO
Postby Box » Thu Dec 04, 2014 12:09 am
The Grey are the back faces, or inside faces. The orientation of the faces can be crucial to how the faces are used in renders and printing. Get in the habit of keeping them the right way around.
On your model it's actually quite simple. Right click on one of the white faces and select Orient Faces.
I reread your post, the trick to fixing those faces is to click on the face and delete it not on the edge. In a couple of places there are three or more faces stacked on top of each other.
Postby d12dozr » Thu Dec 04, 2014 12:21 am
Hi NCO, welcome to the forum!
Like Box says, Sketchup created duplicate faces in the model. You could go and click on each one of them and delete them, but a faster way is to simply open the group, Select all > Cut > Paste in Place. This almost always works to immediately remove all the duplicate faces. It's a weird quirk of Sketchup.
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby NCO » Thu Dec 04, 2014 7:36 am
Thanks for the help guys, really appreciated.
NCO
Return to SketchUp for 3D Printing
