Problem with RepRap Thermistor
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby rodrigonotor » Wed Jul 23, 2014 4:45 am
Hi, some time ago, I build a RepRap Prusa. Everything is ok until a few days.
I used to print with PronterFace and also use Marlin as firmware, but I get an error: the thermistor mark 0 degrees. Change the thermistor, check the wires twice, check the conections, twice also, and everything seems to be ok, but still gives me the same error.
Is any other software that I can use to print?
Thanks in advance. Regards,
Edgar
Sketchando.netwww.arqcad.net
rodrigonotor
Re: Problem with RepRap Thermistor
Postby dukejazz » Sat Jul 26, 2014 9:15 am
Hi Edgar
Thermistor mark 0 degrees mean no power to heating coils
bad switch from a driver lines or the feed data stream missing
use a volt meter to find the break ( you can eye in parts for melts signs or solder legs opens and ribbon cables can open up on you too.)
moving parts can make/break on you also.
did you have a software changes
need more info to help you more.
or
software exporter for your machine may be limited
check with RepRap Prusa
sorry for the wait
dukejazz
Postby rodrigonotor » Sun Jul 27, 2014 7:45 pm
dukejazz wrote:Hi Edgar
Exact, the extruder don't heat
dukejazz wrote:bad switch from a driver lines or the feed data stream missing
I already use a voltimeter for check twice the wires.
dukejazz wrote:did you have a software changes
Change PC
dukejazz wrote:software exporter for your machine may be limited
Any other software like Cura o Slic3r?
dukejazz wrote:sorry for the wait
No problem, thanks for your attention.
dukejazz wrote:check with RepRap Prusa
I already search in reprap forums but I can't solve my problem.
Regards
rodrigonotor
Postby dukejazz » Mon Jul 28, 2014 7:03 am
Is this the system unit you have
RepRap 101: Installing a hotend thermistor with silicate-based cement | ZennmasterM
https://www.youtube.com/watch?v=Y3CffV7VkOQ
- you says wire paths are not broken or no unsolder legs to IC and computer were change out or check and software is ok and no fall off SMT parts.
now testing a Thermistor ( bad feedback of Thermistor will shut down system)
you can test Thermistor with outside heat sorce on it (in and out of systems) using the omh meter settings
Thermistor for measuring/controlling temperature | RimstarOrg
https://www.youtube.com/watch?v=9opuvLXAetI
if this change with temp then the heater source or coil filement is not working or not on
(somthing is over heated and open or burn out)
if the modulator signal is working to the heating sourcr then it's the power thansitors or heater elements.
(now use diode setting of meter)
Your power thansitors maybe open or shorted out. or/and also may took out a system fuse or circuit breaker trip or a cheap resiter burn open.
need info - wait time for your finding.
note: bad parts you can see vent holes or melts or cracks
my bet its the heater element open up on you. heater coil or laser can go out with time.
dukejazz
Postby rodrigonotor » Wed Jul 30, 2014 3:08 am
Many Thanks Dukejazz! I take a look to the links and comment to you later.
Regardas
rodrigonotor
Postby rodrigonotor » Mon Aug 04, 2014 9:37 pm
Hi Dukejazz, sorry for the late.
I messure the direct on the thermistor, a 100k epcos https://ultimachine.com/content/thermistor-100k and show me 95.2
Later, I messure at the end of the cable and show me 93.2
It's ok that numbers or or should show 100.
I read, in some place, that 90-95 should be a good lecture.
Also, I use other type of thermistor, (don't have espec for that kind of thermistor). When I connect the other thermistor (not the 100k epcos), Pronterface (aka Printrun) read 245C that also is not right
rodrigonotor
Postby dukejazz » Mon Aug 04, 2014 11:07 pm
thermistor value will change with temp (hold a ice bag near it to see if you meter have any change in reading)
if you have change with tempiture then thermistor is not broken
the thermistor need good contack to nosle ( tape, glue, screw down or cemented greesed ) no contact mean 0 deg c to you machine
I readed yesterday you need to keep nosle head clean ( with a clearner )
why because the heat scorce iron needs to conduct heat to element rasin to melt
You have to have both electron flow to nosle iron and iron heat tranfer to element rasin and then to thermistor to give a feedback to keep machine runing.
dukejazz
Postby rodrigonotor » Tue Aug 05, 2014 11:57 am
Hey! Thanks, I put my fingers in the thermistor and change the value. Now, i am sure the thermistor is ok. I think it's going to be a software problem.
rodrigonotor
Return to SketchUp for 3D Printing
