3D printing Tips and tricks needed for model
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby solo » Mon Jul 14, 2014 9:44 pm
I need to get an organic model ready for printing, it's heavy, bloated and has lots on tiny holes.
I have SuSolid but this model may need a 3rd party help.
Anyone got an idea of how to get this solid and ready?
http://www.solos-art.com
solo
Global Moderator
Re: 3D printing Tips and tricks needed for model
Postby dukejazz » Mon Jul 14, 2014 10:16 pm
Simplify3D Software Now Available for German RepRap 3D printers | ENGINEERING.com
"The software, especially the slicing functionality, has a big influence on the print quality. Simplify3D"
can yout model be slice then simplefied
do you have jpg or skp of what your working on
it hard to see the holses in your model
To work for a solution. need more info
dukejazz
Postby solo » Mon Jul 14, 2014 10:27 pm
The problem is I cannot show or share the model as it's a prototype for a company. I did the model a while back and printing it was never mentioned then so I modeled for patent purposes only, now they need to print it and the model is not water tight.
Is there a software out there that can skin a model? create a solid model from a crappy one?
solo
Global Moderator
Postby dukejazz » Mon Jul 14, 2014 11:03 pm
This is the same problem in many fields like space and the medical field, its hard to clean a course surface, to get a smooth surface the stacking surface layers can't be greater then 45 degree from vertical.
Also if you can model it by slicing them many times and then simplified. This will make it smoother exterior
I feel interior cutouts of any shape should be a unbroken spear, it ok to elongate it vertical but not horizontal when you test the layer center of volume make sure it moments is balance so it doesn't fall over
If you use object is used in multiple direction some stiffing may be needed and use a perfect spear, to cut-out from interior solid objects from counterpoint
Rule of thumb:
Stable object is a pyramidal shape that wont fall over in earth quake, right!
Strong inter shape think of romans arches or domes
Quick and dirty way of making it water tight:
Print haft then spray water sealent on the inside and then coat the outside with a coat of your materials or aniode meteals, or for plasic spray acetone after printing object. (fit hafts togather with a glue bound with wegets)
You can use a 3d pen to fix defects
Also beteen the thin skin inside and outside walls is a 3d skin mesh may be used:( make it water tight)
to make 3d skin inner spear mesh use the joint push-pull tool-Fredo6 then interface with model trim out side away.
dukejazz
Postby olishea » Mon Jul 14, 2014 11:22 pm
Meshlab and Netfabb
oli
olishea
Premium Member
Premium Member
Postby olishea » Mon Jul 14, 2014 11:23 pm
oli
olishea
Premium Member
Premium Member
Postby d12dozr » Tue Jul 15, 2014 12:24 am
There is also an online version of Netfabb that is much more powerful than the downloadable version. Simply upload your model as an .STL file (exporter available here), and in a few minutes you can download a cleaned, and usually watertight model ready for 3D Printing.
That service has not failed me yet, and their terms of service say they will treat your model with confidentiality. It may fail if the model has large parts missing, as the fixing is all automatic, but if the model just has lots of small errors you should be just fine.
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby solo » Tue Jul 15, 2014 4:25 pm
d12dozr wrote:There is also an online version of Netfabb that is much more powerful than the downloadable version. Simply upload your model as an .STL file (exporter available here), and in a few minutes you can download a cleaned, and usually watertight model ready for 3D Printing.
That online solution was the monkeys balls, worked like a charm.
Thanks you and everyone above.
solo
Global Moderator
Postby olishea » Tue Jul 15, 2014 6:15 pm
Glad to hear it's sorted! :thumb:
Marcus told me about that netfabb a while back and it's been great, although I didn't realise there was a difference between online version and downloadable one. :thumb:
When/if you get permission to disclose the project, why not share some images of the printed model? Good luck and all the best Pete.
oli
olishea
Premium Member
Premium Member
Postby dukejazz » Wed Jul 16, 2014 8:24 am
I just found this today
Just a tip
freeform is a free program
Just bring your object to freeform and then you transfer to Sculpteo then it has a auto 3d print function with some menus that will 3d print then by a 3d print service and then auto mailed them back to you. all objects will be analyze before the service prints them.
So no junk gets printed.
I don't think its auto fix skins to every model? just those made in freeform
I need to play with freeform soon
Decoding 3D Printing: Sculpteo @ Autodesk | Edwin Abarca
https://www.leapmotion.com/blog/decodin ... -autodesk/
"How we think about everyday objects is changing with accessible 3D printing, and new tools are emerging to make it easier to design and create just about anything you can imagine. Sculpteo and the Autodesk Gallery recently hosted a “Decoding 3D Printing” workshop to help hobbyists and professionals get up to speed in an afternoon
The idea behind Freeform is simple – it takes days to learn a CAD program just to make a simple object that you could make in a few seconds with clay. In turn, Sculpteo opens up 3D printing to everyone, so you can make anything from a figurine to an artificial limb after designing it on your computer. Naturally, this gets us excited for what the future has in store. As always, hope to see you at the next meetup, and keep dreaming!"
dukejazz
Postby d12dozr » Wed Jul 16, 2014 11:02 am
solo wrote:That online solution was the monkeys balls, worked like a charm.
Excellent! Glad to hear that, Pete :thumb:
d12dozr
Top SketchUcator
Return to SketchUp for 3D Printing
