Adventures in 3D printing Sketchup models
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby d12dozr » Tue May 13, 2014 2:45 pm
We've seen the news stories - "3D printing will revolutionize manufacturing"...yadda, yadda...but what does that mean for those of us that have never used it? How is 3D printing useful for architects and other Sketchup users? How is Sketchup useful for folks wanting to get into 3D printing?
This thread is for folks to share Sketchup projects they have 3D printed. So post your projects, or just follow along and ask questions if you have any!
I have had a fair amount of experience with 3D printing Sketchup models and learning what works, and what doesn't work so well. Rich has made me a moderator in this sub-forum, so I'll do my best to help you with any questions!
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Re: Adventures in 3D printing Sketchup models
Postby d12dozr » Tue May 13, 2014 3:03 pm
3D Printing is for - Custom parts!
Just this weekend, I had the opportunity to help an elderly couple that deliver the local newspaper. They ride in the car together - Richard carries the papers in to stores, and Ginny puts papers into plastic bags for home delivery. She wanted a way to hold the bunch of plastic bags near her for easy access, so I printed them a custom hook.
Here's the design process in Sketchup, from right to left:
Here is the hook freshly printed:
...and in place in their vehicle:
They were delighted! Because I have a little desktop printer, the raw material only cost 12 cents, and was ready in one hour from start of designing to fresh, hot plastic hook.
For a simple project, this is a classic practical example of how owning a 3D printer can be useful.
d12dozr
Top SketchUcator
Postby cotty » Wed May 14, 2014 7:24 am
One older example: Repair of a roller of an office chair
... and it's still rolling ;)
cotty
Top SketchUcator
Postby cotty » Wed May 14, 2014 7:29 am
A little octahedron ceramic vase modeled with the Artisan plugin.
cotty
Top SketchUcator
Postby kaas » Wed May 14, 2014 8:43 am
Did a 3d print job recently for a former client (I remodeled his house a few years ago). Can't share too much details but will share my process and tips.
It was a study for a technical part. I worked on my computer at the clients office for several days refining concepts on the fly based on their requests. At the end of each day the most interesting concepts were send to 3dhubs for low resolution 3d printing. After several sessions the top 3 concepts were send to a 3d printing firm that could print in higher quality.
My tips for modelling:
* check the specs for the 3d printer you're going to use. Adding smaller details than it can handle can result in messy surfaces.
* model scale 1 : 1 but set the units to meters (so 50mm becomes 50m). Just before exporting to stl set the units back to mm's again. Reason: Sketchup Booleans can't handle small units well.
* use a style showing endpoints and/or 'color by edges' to track down problems
* if the object is symmetrical, only model half. Keeps Sketchup fast, gives better view into the object and also helps some of the plugins.
* my first concept was modeled as a 3d shape and I would cut and add detail to it (Booleans). Problem with complex / double curved volumes is: if you want to alter one curvature, you may have to start all over again. So I switched to modelling using lofts.
* model with contours (curves and splines) and build the 3d shape with Fredo6 Curviloft. Keep a constant amount of edges for the contours. With Fredo6 Curvizard you can simplify the contours if Sketchup is getting slow OR the model becomes too complex.
* think in simple volumes and build the parts for an assembly (see image): white is lofted volume, green will be added using Booleans, red will be subtracted using Booleans.
* in Sketchup I set up a sort of assembly line: I modeled the splines at the origin, copied those a short distance next to the splines and started lofting there. Copied the result a short distance next to it and mirrored the loft and welded into a volume. Copied all the volumes next to it and did the booleans there, copied the end result next to it and did the final cleanup there. By doing so, you can easily switch back to the original shapes without destroying any of them.
* use ThomThom's SolidInspector for checking the Booleans.Use Tig's Weld for welding the mirrored parts together.
* the Booleans will likely fail once the objects get a bit more complex. I ended up moving only those surfaces the booleans would affect above the model and do an 'Intersect With Selected' using the objects you want to add / subtract. After that, copy these lines into the surfaces and do some manual work. Move the modified surfaces back below and weld it into the object.
* export using SketchUp's stl import/export plugin. Check your stl file in HeeksCad or CadExchanger. Saving the stl again it in these programs often makes the file size smaller without loosing any details.
I think I have covered most of it. First time I saw the 3d printed object after looking at it at a screen for a day is a strange but nice experience I must say.
Max
kaas
Postby d12dozr » Wed May 14, 2014 11:22 am
cotty wrote:One older example: Repair of a roller of an office chair
:thumb: great use of Sketchup and 3D printing to solve a problem in daily life
cotty wrote:... and it's still rolling ;)
:) you did a good job!
That ceramic vase turned out very well. I have my first ceramic model arriving in a couple of weeks :bounce:
kaas wrote:Did a 3d print job recently for a former client (I remodeled his house a few years ago). Can't share too much details but will share my process and tips.
Max
Excellent tips, Max...especially this one:
kaas wrote:in Sketchup I set up a sort of assembly line: I modeled the splines at the origin, copied those a short distance next to the splines and started lofting there. Copied the result a short distance next to it and mirrored the loft and welded into a volume. Copied all the volumes next to it and did the booleans there, copied the end result next to it and did the final cleanup there. By doing so, you can easily switch back to the original shapes without destroying any of them.
That's the exact same process that I use, and is shown in effect in the Sketchup screenshot of my car hook above.
kaas wrote:I think I have covered most of it. First time I saw the 3d printed object after looking at it at a screen for a day is a strange but nice experience I must say.
Agreed - the scale of an object can be hard to judge on screen, since you can zoom up as close as you want. I'm often surprised how small my 3D prints turn out, even though I know what scale they're modeled at.
d12dozr
Top SketchUcator
Postby d12dozr » Wed May 14, 2014 11:28 am
3D Printing is for - Scale Models!
While making a custom hook is no reason to go out and buy a printer, this following example may hit closer to home for the architects on the forum.
A project I posted a few weeks ago, this scale model of a tiny cabin is useful for helping customers understand the layout of the home, and for marketing to potential customers.
3D Printed teeny tiny cabin in color
d12dozr
Top SketchUcator
Postby olishea » Wed May 14, 2014 4:05 pm
cotty wrote:A little octahedron ceramic vase modeled with the Artisan plugin.
Hey cotty,
When you sent the model away for printing, did the STL preview look all faceted?
I ask because I was going to 3D print a ceramic stand, it looks smooth as hell in the sketchup model. But when I saw the preview from i.materialise, it looked all faceted, like it needs another couple iterations of subsmooth. I had to ditch the project until I get used to another program, shame because it was a contract with a big company in the UK.
With it being ceramic, are these facets actually noticeable?
I was under the impression the only way I could solve it is by using a solid modeller, like MOI 3D....but your model looks all nice and smooth, even though it has less polygons than mine below. I didn't order a sample because I need to print over a 1000 of these, I just need to get it right.
Here is the preview they sent me....see the facets?
(I know part of the structure is unsupported where the arrow points, I have actually resolved this now)
oli
olishea
Premium Member
Premium Member
Postby cotty » Wed May 14, 2014 5:17 pm
Here's the preview from shapeways, it looks faceted too.
In fact, I think the process will not allow faceted faces even if you want it that way because of the glazed surface. The face is much smoother than expected.
cotty
Top SketchUcator
Postby solo » Wed May 14, 2014 5:28 pm
These are cool and all but what are the costs of a model? Can you tell me from above examples how much they cost in materials and time it took to make?
http://www.solos-art.com
solo
Global Moderator
Postby cotty » Wed May 14, 2014 5:59 pm
solo wrote:These are cool and all but what are the costs of a model? Can you tell me from above examples how much they cost in materials and time it took to make?
The delivery time depends on the material, in my experience: from a few days to 3 weeks.
Price preview for the vase model:
cotty
Top SketchUcator
Postby cotty » Wed May 14, 2014 6:19 pm
A holder of our plissés was repeatedly broken, now it is replaced...
(Alumide: ca. 2 Euro, Steel ca. 8 Euro)
cotty
Top SketchUcator
Postby olishea » Wed May 14, 2014 8:15 pm
Solo, they offer discount for bulk orders too.
Thanks cotty, that really confirmed my suspicions. Guess I was stressing out over nothing! haha
oli
olishea
Premium Member
Premium Member
Postby solo » Wed May 14, 2014 8:26 pm
What I really want to know is the price if you have your own machine, I'm contemplating buying one, but do not know which one or what material yet.
solo
Global Moderator
Postby d12dozr » Wed May 14, 2014 8:56 pm
Pete, a part made on a home printer will cost roughly 1-5% of a professionally printed part, but you also have a lot more work involved and will get a much lower quality product.
This cabin was printed on a pro printer (Full Color Sandstone from Shapeways) for ~$150:
Full Photo Album
The same cabin printed in ABS plastic on my home printer for $2.25, not including the 3 failed prints - and the model doesn't look nearly as good.
Full Photo Album
If I knew how to operate the printer better, I could get better prints. I've had it for 6 months now, and have had 1 major problem where I had to tear apart the extruder to clean out jammed filament, and several smaller problems that took a few hours of troubleshooting to correct. Home 3D printers are NOT plug and play yet, and it really depends on your needs and skill level if you want to buy a printer.
An analogy of using a print service vs your own printer would be sending a Sketchup model to a professional render guy and getting back a nice polished render made with Thea, vs. trying to figure out how to use Kerkythea on your own with no prior knowledge of rendering.
d12dozr
Top SketchUcator
Postby olishea » Thu May 15, 2014 4:20 pm
Carsten, I bet you just look for broken components in your home so you can print a replacement! haha great work!
oli
olishea
Premium Member
Premium Member
Postby cotty » Thu May 15, 2014 4:35 pm
olishea wrote:Carsten, I bet you just look for broken components in your home so you can print a replacement! haha great work!
It's that obvious? 8-)
cotty
Top SketchUcator
Postby d12dozr » Thu May 15, 2014 4:51 pm
3D Printing is for - Jewelry!
These are pieces that I designed in Sketchup, printed via Shapeways and i.materilise, and sell to medical professionals online. The parts are not 3D printed directly, but rather a wax model is 3D printed, then placed in a plaster mold, and finished using lost-wax casting and hand polishing of the parts. The best thing is that the print services take care of all the work, sending my customers or myself the perfect finished part.
The pendants sell from $69 for the smallest silver one to $450 for the big gold pendant.
Sterling Silver
Solid 14K Gold
Solid 14K Gold
Solid 14K Gold
Sterling Silver
d12dozr
Top SketchUcator
Postby olishea » Thu May 15, 2014 5:13 pm
WOW!!! do you sell the chains too? They really don't look like they've been printed at all....I know they've been cast from a print but they are sooooo smooth! :thumb:
oli
olishea
Premium Member
Premium Member
Postby d12dozr » Thu May 15, 2014 5:28 pm
I was seriously impressed with that big 14K gold pendant. Shapeways just started offering gold a month ago, and that was the first thing I ordered. They sent it out in that nice case (for free!), which is a really nice bonus. I had it in hand in just 7 business days!
I don't sell the chains, but have been thinking to add them. It's one more thing to have on hand and keep track of, but it may well be worth it.
d12dozr
Top SketchUcator
Postby d12dozr » Fri May 16, 2014 12:37 am
solo wrote:What I really want to know is the price if you have your own machine, I'm contemplating buying one, but do not know which one or what material yet.
Pete, the best way to get a feel for these printers is to see one in person. There are local makerspaces in nearly all major cities that will let you come and take a look for free, or pay a monthly fee join to use the tools.
I looked up one in Dallas called the Dallas Makerspace: http://dallasmakerspace.org/
From their calendar, they have an Open House every Thursday night where you can pop in, get a tour, and ask questions. I have found the folks that frequent makerspaces are very receptive to questions and helping others get started in 3D printing and other useful skills. They can help you understand the different kinds of 3D printers and help you choose one that'll work for you.
For anyone else wanting to learn more about 3D printing, finding a makerspace (also called hackerspace) to see a printer in action and ask the regulars questions is an excellent way to get started. Here are a few ways to find groups with 3D printers:
d12dozr
Top SketchUcator
Postby olishea » Fri May 16, 2014 9:41 am
Sending off a model to i.materialise today. Let's see how it works out! I was up literally all night, when I sleep I'll be dreaming in quads! :lol:
Quick question. For price comparison I'm also sending model to shapeways. It has to be in STL format and I'm using meshlab to export. So I'm exporting as Collada, importing into meshlab and exporting STL.
Problem is, my model is coming out tiny, significantly smaller than it should be. Any ideas what I'm doing wrong?
[edit] found a STL plugin which works fine, still can't think why the other method didn't though, even though I specified model units.
oli
olishea
Premium Member
Premium Member
Postby d12dozr » Fri May 16, 2014 10:53 am
I'm guessing model units are getting mixed up in the process. Do you know about the STL exporter? If you use that, it's just one step and there shouldn't be any trouble! Protip - you can ZIP the file before uploading to speed the process.
d12dozr
Top SketchUcator
Postby olishea » Fri May 16, 2014 12:12 pm
That plugin didnt work for me on mac, version 8 sketchup. The created files contain no geometry and I've tried changing every option.
I used this one instead, worked first time. So easy!!
http://brettbeauregard.com/blog/2011/06 ... o-dialogs/
oli
olishea
Premium Member
Premium Member
Postby d12dozr » Fri May 16, 2014 12:59 pm
Nice find!
d12dozr
Top SketchUcator
Postby notareal » Fri May 16, 2014 8:15 pm
cotty wrote:...
btw if some one is planning to print custom lego parts, "coral red strong & flexible" is rather close to lego red ;)
notareal
Thea Render Support
Thea Render Support
Postby otb designworks » Fri May 16, 2014 11:24 pm
I got to work with metal printing company for a few years.
My workflow is pretty much exactly how you guys do it; my Su models are often times 20 or more versions all 100', 200', 300' from origin.
I have used SU, Cheetah, and Zbrush all to great effect. Honestly, both of those softwares are inherently "better" than Su for making models for printing. Cheetah uses a modifier stack system which makes editing almost pleasant. Z brush is badass in many aspects (displacement painting with alpha masks, realtime multiple customizable symmetry operations, what?!) but it is a completely different flow than a 3D modeler.
That said, I still use SU the most, mostly because I am faster in it than anything else. Oftentimes, I make the base model in Su, then into Cheetah or Zbrush for sculpting, SubD, etc. And anything architectural was SU and then Z brush for surface sculpting (choosing a stone image and then using it to paint displacement onto a base mesh and then cranking the polygons to 200 mil for final blending and detailing sure is mind blowing and makes you hate SU for what it isn't and can't do.
The stainless steel/bronze had a precision of .007". I settled on a 1/8"=10' printing vs modeling scale.
Here is a video I put together showing some of the renders I did during design development:
https://www.youtube.com/watch?v=NTP7hZl7JwQ
3
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Postby d12dozr » Tue May 20, 2014 10:45 am
Chuck, that is some fantastic work :thumb:
Were the models intended to be used as displays, or what was the end use?
I found a photo of your castle model on this blog post, listed under #4, ExOne 3D printers.
d12dozr
Top SketchUcator
Postby otb designworks » Tue May 20, 2014 4:01 pm
Thanks Dozer!
Exone hired me a few years ago to assist with developing presentation and retail models for marketing to various potential markets.
I developed some architectural models (us capitol, notre dame, castle, falling water, taj mahal), a bunch of cabinet and door hardware, and some islamic themed pieces for marketing to the middle east (I used 14-15 century islamic calligraphy as mu base vectors and then developed them into 3d models; pretty cool, I think, but it just didn't take off.
The metal printing is just, in my opinion, prohibitively expensive. The market for $200 cabinet knobs is pretty small, you know?
Exone went public in mid 2013 ; it's stock shot through the roof, and then it crashed badly last week due to poor quarterlies. Crashed so bad that I guess the entire 3d printing industry took a hit. Exone makes most of it's money, I think, from selling million dollar printers and they were hoping to support a merchandize line as ancilliatory use for their printers (might as well have the running all the time), but the cost just kept it from working out.
I did have a lot of fun playing with Zbrush, Cheetah, Illustrator, and SU developing these and I wish it had gone somewhere...
Cheers, Chuck
otb designworks
Postby d12dozr » Tue May 20, 2014 4:31 pm
Yeah, I think you're right about cost. I see cost as a limiting factor even with professional plastic printing, and is one of the reasons 3D printing isn't used more frequently. When you do get a cheap print, say from a desktop printer, then the quality often isn't good enough to be taken seriously in a professional setting.
d12dozr
Top SketchUcator
Next
Return to SketchUp for 3D Printing
