File Output for 5-Axis CNC Machining?
Get 3D Printing support, tips and tricks for SketchUp
Moderators: dukejazz, d12dozr
Postby EzekielK » Fri Aug 27, 2021 5:38 pm
Got an Art Director asking about using sketchup geometry to drive a 5-axis CNC machine. Have found apps advertised for preparing SU files for the purpose but the process looks torturous and so far as I know SU is not a favored tool for the modeling -> CNC pipeline.
Does anyone have recommendations for a process that works well for moving sketchup geometry over to the CNC side, and/or any typical constraints or difficulties encountered in doing that?
Thanks in advance.
K
EzekielK
Re: File Output for 5-Axis CNC Machining?
Postby Rich O Brien » Fri Aug 27, 2021 6:41 pm
Did you look at SketchUcam?
https://github.com/swarfer/sketchucam/releases
Did you try Freecad to Gcode Export? Or are you dealing with SKP files primarily?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby EzekielK » Fri Aug 27, 2021 9:09 pm
Rich O Brien wrote:Did you look at SketchUcam?
everything is starting as skp files
EzekielK
Postby Rich O Brien » Fri Aug 27, 2021 10:52 pm
Only one I knew is SketchUcam. Sorry, not much else to add.
SketchUp is a poly modeller so TRUE curves aren't possible. You will always fight against segments causing facetting.
I believe SketchUcam's extport to g-code was quite adequate on flat sheet cuts. But 5-axis stuff could be a bit of a stretch.
User avatar
Rich O Brien
Administrator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp for 3D Printing
Who is online
Users browsing this forum: No registered users and 4 guests
