What am I missing beside the trees?
Laubwerk Trees not rendering in TheaModerator: Frederik
• Page 1 of 1
Laubwerk Trees not rendering in TheaAs the title states, the Laubwerk Trees I placed into the model are not rendering when using Thea.
What am I missing beside the trees? ![]()
Re: Laubwerk Trees not rendering in TheaDifficult to say...
It works fine on my laptop... Cheers
Kim Frederik
Re: Laubwerk Trees not rendering in TheaYes they are proxies generated on the fly at render-time.
Re: Laubwerk Trees not rendering in TheaAre you copying the proxies from a model into another or generating new proxies with the plugin in a new model?
Re: Laubwerk Trees not rendering in TheaThe tree models were inserted into the model directly using Laubwerks. The file in question is not a copy of a file. I had this problem before when I mixed trees from skatter and Laubwerks trees, but that is not the case here.
Re: Laubwerk Trees not rendering in Thea![]() ![]() It's working fine now. Thanks for the replies and sorry for wasting your time.
Re: Laubwerk Trees not rendering in TheaI'm having the same issue, but as far as I can tell it is installed through the extensions manager. It's been a while since I first installed it, but is there a different installation that I need? The trees do not render in Thea.
Are you trying to render a file that has the tree models in already? Try inserting a Laubwerk tree in from the library and see what happens. Also, I believe you need to use the Laubwerk installer, not the SU extension installer.
please tell me what's the su 2018 ? Re: Laubwerk Trees not rendering in Thea
SU 2018 is SketchUp 2018. I did not install the latest version of Laubwerk, so when I was rendering a file created in a previous version of Sketchup, the trees placed in the model using the Laubwerk app did nor render. Once I updated Laubwerk, the file renedered properly.
• Page 1 of 1
