SU crashes rendering in SU with Thea IR-Presto(MC)
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby Michel B » Mon Jul 24, 2017 7:12 pm
Hello,
Sketchup crashes every time I run an interactive render inside the SU Window with Thea IR-Presto(MC).
I have this problem since my computershop installed a new cooling unit, repaired some startup files en updated the GPU drivers.
This is my setup:
* Intel Core i7 3930K 3.2 GHz
* NVIDIA GeForce GTX 1060
* NVIDIA GeForce GTX 760
* Thea Render Galileo 1.5.07 (64bit)
* Windows 10
(I'm rendering on the GTX 1060)
Any suggestions on how I can solve this problem? Thank you for your cooperation.
Best regards, Michel
Michel B
Re: SU crashes rendering in SU with Thea IR-Presto(MC)
Postby alpro » Wed Jul 26, 2017 1:46 am
First thing I would try is make sure the Nvidia drivers are up to date.
alpro
Premium Member
Premium Member
Postby Rich O Brien » Wed Jul 26, 2017 11:47 am
Make sure you are on the latest Thea For SketchUp build if using Windows 10 and SketchUp 2017
Rich O Brien
Administrator
Postby Michel B » Wed Jul 26, 2017 6:28 pm
I've updated the Thea Plugin for Sketchup and everything is running fine now.
Thank you for your help.
Michel B
Return to Thea
Users browsing this forum: Google Bot and 1 guest
