Sketchup 2017 and Kerkythea
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby b60 » Sat Apr 22, 2017 7:29 pm
I didn't see an entry for Kerkythea, but this is close!
I installed Sketchup 2017, then tried to install KT via the download page link.
It didn't work. So I tried the Echo Boost, which worked except that the
render pre-sets were missing. So I tried the SU2KT updated version and that
worked except that it kept repeatedly crashing and no matter what I tried,
the material libraries (all mat.zip) would not install (unknown extension,
etc.).
No permission problems. KT path is
Users>Name>AppData>Roaming>Sketchup>Kerkythea. 16 GB Ram, Windows 8.1.
What can I do to fix this? Is there an updated Echo Boost that solves the
pre-sets problem? I tried to post this message on the KT forum, but it had never appeared, and the forum seems inactive.
b60
Re: Sketchup 2017 and Kerkythea
Postby pilou » Sat Apr 22, 2017 9:11 pm
You can try Twillight 2 Hobby same family render than Kerkythea
No limit of size and no watermark!
It is also free and can be use for commercial use!
And also the free Real Time render Simlab Composer Light Maxi 19020 * 1080, no watermark
Can be use for commercial use!
Speedy Galerie
Top SketchUcator
Postby b60 » Sat Apr 22, 2017 10:01 pm
pilou wrote:You can try Twillight 2 Hobby same familily render than Kerkythea
I may have to do one of those, but for now I really want to make KT work!
b60
Postby NigeC » Sun Apr 23, 2017 11:55 am
look in registry to see were the paths are pointing to, I seem to remember if you've installed multiple versions the registry screws up. also the installers are old Win7 was just coming in.
I think Wings 3D also had problems finding presets, so it might be worth looking on their forums
So search regedit to see were KT is actually installed to and that there isn't multiple versions
Personally I'd use Twilight 2 Hobby
“It’s only impossible if you stop and think about it!”
NigeC
Postby JQL » Sun Apr 23, 2017 2:59 pm
Mine is working fine on Win10
JQL
Premium Member
Premium Member
Postby pilou » Sun Apr 23, 2017 4:57 pm
There were also problems with "accent" inside files name path!
Speedy Galerie
Top SketchUcator
Postby b60 » Wed Apr 26, 2017 12:20 am
Thanks to all! I did find an updated SU2KT plug-in on the KT forum (.rbz) and that works!
b60
Return to Thea
